sea_lyons Posted April 1 Share Posted April 1 Is there anything similar to this door style in any of the Chief Catalogs that I'm just not finding or have not yet downloaded maybe? Link to comment Share on other sites More sharing options...
GeneDavis Posted April 1 Share Posted April 1 Beaded panel doors are possible. Model one yourself using countertop tools, save it as a door, with appropriate stile and rail widths and stretch planes. Beaded faceframe surrounds are above my pay grade. See what one of the cab gurus has to say. I'm sure one will be along soon. 1 Link to comment Share on other sites More sharing options...
robdyck Posted April 2 Share Posted April 2 It's almost certainly faster to make one than to find one. Try this one out. cab door.calibz 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted April 2 Author Share Posted April 2 On 4/1/2025 at 3:59 PM, GeneDavis said: Beaded panel doors are possible. Model one yourself using countertop tools, save it as a door, with appropriate stile and rail widths and stretch planes. Beaded faceframe surrounds are above my pay grade. See what one of the cab gurus has to say. I'm sure one will be along soon. I've made other cabinet door profiles with 3D Solids but those were with 90 degree edges, nothing beaded. Maybe I should have tried with countertop tools instead? 5 hours ago, robdyck said: It's almost certainly faster to make one than to find one. Try this one out. cab door.calibz 217.25 kB · 18 downloads Ahh this is great, thank you!!! Can I ask how you did the beaded part? 1 Link to comment Share on other sites More sharing options...
robdyck Posted April 2 Share Posted April 2 1 hour ago, sea_lyons said: Ahh this is great, thank you!!! Can I ask how you did the beaded part? As a startign point, I found a door that was very close. The frame and bead were ok, but it had a raised panel. So I used the delete surface tool to reomve the raised panel and then created a symbol and placed it in plan view. I then added a 3d solid for the center panel and a molding for the detail between the bead and panel. I then select those 3 part and create a new symbol assigned to the cabinet door/drawer category. I set the stretch planes to be centered on the width and height of the panel, and add to my library. I didn't search the library very long, but it still would have been faster to have created the door from scratch. A molding polyline can be used for the outer frame and then duplicated and re-sized for the bead and detail. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted April 3 Share Posted April 3 Countertop is the place to start as Rob says but I'd do it a bit differently. I'd make the molding a different material than the panel and I would NOT make the door frame until later. Sequence shown here. Counter, Wainscot Cab Door symbol, Wall Cabinet with wainscot symbol in it, final cabinet door, then used in cabinets. Prior to converting to symbol the panel, molding, and the frame each have a different material. When converting to symbol (advanced options) rename each part and set each to use the plan default. Now you have symbols with flexibility. The wainscot panel can be used on the ends of cabinets, it also allows you to make new door symbols with different rail and stile sizes almost instantly, and finally using different materials allows you to quickly make a glass panel door. it can be very fast (as long as you remember to make the back of the cabinet to none or it won't properly become a glass panel door...DAMHIKT) 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted April 3 Author Share Posted April 3 I did it!!! Thanks all! I use molding lines/polylines quite a bit but didn't realize they could be used to make doors - this is way more streamlined than what I've been doing until now. So much wasted time lol... 3 Link to comment Share on other sites More sharing options...
PamelaT Posted April 24 Share Posted April 24 MarkMc Where do you convert the custom counter top to a wainscot panel? I have created a custom door with 3D solids and would like to put a bead on the inside of the cutout. Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted April 25 Share Posted April 25 20 hours ago, PamelaT said: Where do you convert the custom counter top to a wainscot panel? Hi Pamela. First a tip. If you want someone to get notified to look at a post put an @ symbol"the user name" OR highlight some text in their post and select Quote Selection when it pops up. I just got back and the only reason I saw this was looking at what was posted since I left. I almost never use solids for making a door symbol so I'm not sure how you would use the wainscot panel with that without just floating it in. Here is a link to a post with the door maker plan I use. I may have updated it but this works. 1 Link to comment Share on other sites More sharing options...
PamelaT Posted April 25 Share Posted April 25 @MarkMc, Thank you for your reply. I actually used the trim tool (under "Build" ) to create the bead. I will take a closer look at the link you generously posted. Thank you, Pamela Link to comment Share on other sites More sharing options...
