Breeze_Design Posted yesterday at 04:32 PM Share Posted yesterday at 04:32 PM A customer (contractor / cabinet maker) has just acquired a CNC machine and has asked if there is anything I can do to integrate my CA plans with their Mozaik software. I'm just starting to look into Mozaik and wondering if there is any compatability / import possible, even if it requires a separate software connector? Link to comment Share on other sites More sharing options...
JiAngelo Posted 20 hours ago Share Posted 20 hours ago Dxf import/export is possible. Link to comment Share on other sites More sharing options...
MarkMc Posted 20 hours ago Share Posted 20 hours ago 36 minutes ago, JiAngelo said: Dxf import/export is possible. I was working with a client using Mozaik and as far as we could tell dxf would only import individual shapes. They did not find a way to import a chief plan, full 3D or even an individual cabinet. Do you know otherwise from experience? If so I'd like to pass it on to them. Link to comment Share on other sites More sharing options...
KevinWaldron Posted 1 hour ago Share Posted 1 hour ago If CA built cabinets with solids this would maybe be possible, but all we are getting is a skin/covering/representation. A face frame for instance is not 3/4"-5/8" thick when using the cabinets found within CA and not built or drawn to be reproduced with machine. CNC requires materials that have XYZ sizes as that is the way that it finds it's way in space. Laser work on the other hand typically requires only XY locations. So you could do a paper cut out of the cabinets with laser. Link to comment Share on other sites More sharing options...
