Gawdzira Posted March 23, 2015 Share Posted March 23, 2015 I have been monkeying with this for months. I just tried another round of "what if I do this?" but nothing is working. I can get the roof plane and sheathing to correct itself and as soon as I do a few other commands it pops back to the state in the image. It may just be a bug based on the window box and the attic wall configuration. Any ideas? F7 Planning App Rev 1a.zip Link to comment Share on other sites More sharing options...
dshall Posted March 23, 2015 Share Posted March 23, 2015 Alan, I have experienced this only once before, and I was never able to figure out the problem. I will take a quick look...... no matter what I figure out, I think you might want to send this into tech. Mine was not based on the window box. Link to comment Share on other sites More sharing options...
MPDesign Posted March 23, 2015 Share Posted March 23, 2015 Hey Alan, Only a layout file in zip folder. Link to comment Share on other sites More sharing options...
dshall Posted March 23, 2015 Share Posted March 23, 2015 Alan, the Layout is there but no plan. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 23, 2015 Author Share Posted March 23, 2015 Classic bozo move. F7 dd rev2.zip Link to comment Share on other sites More sharing options...
dshall Posted March 23, 2015 Share Posted March 23, 2015 Alan, your situation was not like mine. You are using the box window. I would never use that. I never use that (I used it once I think), I always have problems with it. Take a look at an interior view, it is a mess. Maybe someone else can give you a quick solution, if not, if I have time I might do a vid on how I would do this. It probably is fairly easy to do if you do not use the box window option. Hopefully someone can prove me wrong and make it work with a box window. We will see. Maybe that person can fix it using the box window solution and then post the plan. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 23, 2015 Share Posted March 23, 2015 I got it to go away by messing with that roof plane, not exactly sure what I did but just squared off the back of that plane. F7 dd rev3.zip Link to comment Share on other sites More sharing options...
dshall Posted March 23, 2015 Share Posted March 23, 2015 I got it to go away by messing with that roof plane, not exactly sure what I did but just squared off the back of that plane. I agree, however if you look at the plan, the roofs on each side of box window are not located in the same location in plan view and the interior view is a mess. If both of those issues are not an issue, then it is fixed. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 23, 2015 Share Posted March 23, 2015 ok, I really didn't look at anything else. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 23, 2015 Author Share Posted March 23, 2015 Perry, I think that is the trick. I just needed that roof plane to be what it should be. Thanks, Alan Link to comment Share on other sites More sharing options...
