sea_lyons Posted December 9, 2024 Share Posted December 9, 2024 This has happened to me on a few occasions - not sure if it's a glitch or something in my camera settings. Tried changing camera angles, tried a different mirror material out of the library, all to no avail. How it looks on my layout file: How it looks on the PDF: Another example: Layout file vs generated PDF Link to comment Share on other sites More sharing options...
MPDesign Posted December 10, 2024 Share Posted December 10, 2024 Hi Caitlin, A couple thoughts. Are you using the print to Chief pdf in the print dialog? Have you deleted and resent the view? Have to tried to send it to layout as a picture, not live view? 1 Link to comment Share on other sites More sharing options...
basketballman Posted December 10, 2024 Share Posted December 10, 2024 Perhaps do a screen capture of desired image .. 1 Link to comment Share on other sites More sharing options...
DeLayDesign Posted December 10, 2024 Share Posted December 10, 2024 Are you using live cameras to your layout? I've run into a issues in the past with performance when my users send active cameras to the layout; but nothing like this. Personally, I would rather send a static image to the layout. You should give running your view, exporting the image and then bring that image into your layout a try. 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted December 11, 2024 Author Share Posted December 11, 2024 On 12/10/2024 at 8:55 AM, MPDesign said: Hi Caitlin, A couple thoughts. Are you using the print to Chief pdf in the print dialog? Have you deleted and resent the view? Have to tried to send it to layout as a picture, not live view? Hi, Yes, using "Chief Architect Save As PDF". Yes, I've tried deleting and resending. Seems like the consensus is to just send as a picture to layout or save as a picture and import. I'll do that as a workaround in these instances. Thanks all Link to comment Share on other sites More sharing options...
sea_lyons Posted December 11, 2024 Author Share Posted December 11, 2024 23 hours ago, DeLayDesign said: You should give running your view, exporting the image and then bring that image into your layout a try. Ah, here's what the exported image looks like: I guess I'll be sending to layout as an image instead - that seems to have worked. Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 11, 2024 Share Posted December 11, 2024 you might want to log it with CA support. I would think things like this should be fixed, and they may not know about it 1 Link to comment Share on other sites More sharing options...
