Roof Frieze Issue
Steve_Nyhof
Roof returns are done to eliminate the bad architectural practice of having a pork chop end, and unless you give a return its own return (check "hip"), including frieze wrap, as is done by using the molding, you get a pork chop.  Best practice is to do the returns at a lower pitch than the roof above.
I had a great pork chop at a steak joint called Perry's the other night.  But I don't like to see them on roof corners.
5 minutes ago, GeneDavis said:
Roof returns are done to eliminate the bad architectural practice of having a pork chop end, and unless you give a return its own return, including frieze wrap, as is done by using the molding, you get a pork chop.
Boxed eaves, which sounds much nicer than 'pork chops', are built to eliminate the costs associated with roof returns, allowing homeowners to occasionally visit a steak house and not have the embarrassment of publicly ordering a pork chop!;)
  • Like 2
You made me think of this book:
Get Your House Right
Chapter 10 talks about Cornices and Eaves
