SHCanada2 Posted October 28, 2024 Share Posted October 28, 2024 There looks to be 4 different "object" "endpoint" snap points withing a 18" roof eave. Any idea what they are? Is it snapping to things that are not actually showing like the fascia board. For testing, "enpoints" is the only object snap I enabled. Its a lot worse if I turn them all on (although it is the same 4 points) 27.10.2024_20.10.57_REC.mp4 Thanks Link to comment Share on other sites More sharing options...
glennw Posted October 28, 2024 Share Posted October 28, 2024 Do you have Grid Snaps toggled on? Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 28, 2024 Author Share Posted October 28, 2024 no i do not use grid snaps Link to comment Share on other sites More sharing options...
rlackore Posted October 28, 2024 Share Posted October 28, 2024 Turn off "Use Special Snapping" Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 28, 2024 Author Share Posted October 28, 2024 interesting, the definition is: When Use Special Snapping is checked, the selected roof plane's edges will automatically snap to the outside surface of walls that it may butt against. Uncheck this to prevent the roof plane from snapping to any nearby walls. There are no "Walls" in the 4 snap points I show in the video. I just tried it, I still get the same 4 snapping points even if it is unchecked. interestingly the first snap away from the designated eave length is 1-3/16" there is nothing in the roof for that my guess is it is the funky way CA decided to frame the lookout where it looks to be 3 different pieces. anyone seen that? : yup thats it: if I delte them and build all framing they return Link to comment Share on other sites More sharing options...
tundra_dweller Posted October 28, 2024 Share Posted October 28, 2024 Odd behavior for sure. Do you have shadow boards on? Shouldn't matter at all but you never know. Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 29, 2024 Author Share Posted October 29, 2024 no shadow boards... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 29, 2024 Share Posted October 29, 2024 PTP Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 1, 2024 Author Share Posted November 1, 2024 well, figured it out. The two roof planes were initially auto generate, however I was modifying the one on the right for this purpose: Anyway when comparing the two roof planes, the modified one had a different fascia top height. Different by a few 16ths, but when I changed it to match the unaltered one, the ridge did not match, I then examined the roof baseline of the altered one, and it was not at the end of the top plate. I must have accidentally moved it, maybe by grabbing it instead of the roof plane. Bit that layer is not usually on, so who knows. Anyway it is fixed now by moving the baseline. It certainly was an interesting side effect, the odd framing shown above Link to comment Share on other sites More sharing options...
