Gawdzira Posted October 26 Share Posted October 26 Is there a way to achieve this with the Lintel tab in the DBX or is this going to be a custom solid? Link to comment Share on other sites More sharing options...
GeneDavis Posted October 26 Share Posted October 26 Solid. We have the wrap option for lintels, but what you are showing seems like a jigsaw cut on a flat board, not a return (wrap). It'll take you a couple minutes. Hey, it's billable hours, right? Link to comment Share on other sites More sharing options...
Gawdzira Posted October 26 Author Share Posted October 26 I think this will become my next suggestion. We should be able to have lintel control similar to rafter tails. I tried to fake it with a bevel casing and the wrap but the result is not what I would expect. Link to comment Share on other sites More sharing options...
Solution robdyck Posted October 28 Solution Share Posted October 28 You can easily add that as a Treatment > Exterior Millwork Above Casing. Create the symbol using a 3d solid or whatever tool works best for your style, convert it to millwork and add it to the library. Make sure you are using an Exterior Lintel (no profile, width = 0"), then add the treatment and adjust the width as needed. 1 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted October 28 Author Share Posted October 28 Thanks, that works like a charm. 1 Link to comment Share on other sites More sharing options...
robdyck Posted October 28 Share Posted October 28 Glad to hear that! When you get the chance, it might be helpful to others if you mark that post as a solution. 1 Link to comment Share on other sites More sharing options...
tundra_dweller Posted October 28 Share Posted October 28 5 hours ago, robdyck said: Treatment > Exterior Millwork Above Casing I learned something new today thanks! 1 Link to comment Share on other sites More sharing options...
