Window/door lintel bevel angle?
Gawdzira
Go to solution Solved by robdyck,
  • Solution
You can easily add that as a Treatment > Exterior Millwork Above Casing. Create the symbol using a 3d solid or whatever tool works best for your style, convert it to millwork and add it to the library.
Make sure you are using an Exterior Lintel (no profile, width = 0"), then add the treatment and adjust the width as needed.
