Couple of Custom Muntin Questions
HumbleChief
Go to solution Solved by GeneDavis,
  • Solution
Select the window after creating the custom muntin array.  Go to Lites.  Change muntin width to something else.  Worked for me.
As for your connection issue, I've no clue.  Try dividing the arc into three segments, then making each side polyline a side arc and a vertical.  The center segment arc is all by itself.  Then block the three p'lines and see if the verts join to the arcs OK.
THANK YOU GENE! Had no clue about the muntin width setting. I'll probably not mess with the connection issue right now but will keep your idea in mind.
1 hour ago, Gawdzira said:
sort of better? The line is a funky continuous line to avoid the gapping at the verticals. The line length of the muntin must pass the window stop and get in as far as the sash.
image.thumb.png.f28aba42af07f46cad22649dafe0d57c.pngimage.thumb.png.f18e2f1441c806e201458172e7bf8642.pngimage.thumb.png.4705a300cd57917fd3fed758ebfddf6c.png
Yes Alan much better! Who'da thunkit?
