HumbleChief Posted October 9, 2024 Share Posted October 9, 2024 Been working on this for no less than an hour and can't seem to get it right. Any help greatly appreciated. https://www.dropbox.com/scl/fi/xiummhhsepflm3x7v8w3o/MUNTIN-PLAN.plan?rlkey=iiymodnpdpfwv0cbc7evfxtne&dl=0 Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted October 9, 2024 Solution Share Posted October 9, 2024 Select the window after creating the custom muntin array. Go to Lites. Change muntin width to something else. Worked for me. As for your connection issue, I've no clue. Try dividing the arc into three segments, then making each side polyline a side arc and a vertical. The center segment arc is all by itself. Then block the three p'lines and see if the verts join to the arcs OK. Link to comment Share on other sites More sharing options...
HumbleChief Posted October 9, 2024 Author Share Posted October 9, 2024 12 minutes ago, GeneDavis said: Select the window after creating the custom muntin array. Go to Lites. Change muntin width to something else. Worked for me. As for your connection issue, I've no clue. Try dividing the arc into three segments, then making each side polyline a side arc and a vertical. The center segment arc is all by itself. Then block the three p'lines and see if the verts join to the arcs OK. THANK YOU GENE! Had no clue about the muntin width setting. I'll probably not mess with the connection issue right now but will keep your idea in mind. Link to comment Share on other sites More sharing options...
Gawdzira Posted October 9, 2024 Share Posted October 9, 2024 sort of better? The line is a funky continuous line to avoid the gapping at the verticals. The line length of the muntin must pass the window stop and get in as far as the sash. Link to comment Share on other sites More sharing options...
HumbleChief Posted October 9, 2024 Author Share Posted October 9, 2024 1 hour ago, Gawdzira said: sort of better? The line is a funky continuous line to avoid the gapping at the verticals. The line length of the muntin must pass the window stop and get in as far as the sash. Yes Alan much better! Who'da thunkit? Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 9, 2024 Share Posted October 9, 2024 2 hours ago, HumbleChief said: Yes Alan much better! Who'da thunkit? convert your arc to a polyline with more sides and you'll have a better experience with it Link to comment Share on other sites More sharing options...
