Darcen Posted September 19, 2024 Share Posted September 19, 2024 I drafted this timber framed truss with poly line solids, now I want to union them so I shift select all 4 beams and then hit the union key but only 2 will union. I can go back and select the now (3) objects and try to union the remaining and it will not do it. I also would like to work with poly line solids but I cant find poly line options in the X16. can anyone help me out? Thanks! Link to comment Share on other sites More sharing options...
Gawdzira Posted September 19, 2024 Share Posted September 19, 2024 One piece at a time. Select a->b, then a/b->c, etc Link to comment Share on other sites More sharing options...
DBCooper Posted September 19, 2024 Share Posted September 19, 2024 Are all of the objects really polyline solids? As far as I know, it should just work as long as they are all polyline solids and they are actually touching or overlapping each other. I don't think you have to do each piece one at a time either. If you can't figure it out, you might want to post the plan. Link to comment Share on other sites More sharing options...
Gawdzira Posted September 19, 2024 Share Posted September 19, 2024 Yes, 3 at a time worked Link to comment Share on other sites More sharing options...
mtldesigns Posted September 20, 2024 Share Posted September 20, 2024 11 hours ago, Darcen said: now I want to union them Why do you want to union them? Once you do, it becomes harder to manipulate. If it's just because its a PITB to move around, just make it a block. Personally, unless its an actual one piece item, I don't union anything, but that's just me. I have the same mentality in AutoCAD too. Link to comment Share on other sites More sharing options...
johnny Posted September 20, 2024 Share Posted September 20, 2024 1 hour ago, mtldesigns said: Why do you want to union them? Once you do, it becomes harder to manipulate. If it's just because its a PITB to move around, just make it a block. Personally, unless its an actual one piece item, I don't union anything, but that's just me. I have the same mentality in AutoCAD too. 100% agree. Dare I say next to impossible to manipulate effectively post union. Not to mention, if you plan to do any wood texture for a rendering etc you have to have a texture per direction so per wood member (which kinda sucks). I really wish we could build wood structures out of framing members (which auto rotate the texture). Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted September 20, 2024 Share Posted September 20, 2024 On 9/19/2024 at 12:21 PM, Darcen said: I drafted this timber framed truss with poly line solids, now I want to union them so I shift select all 4 beams and then hit the union key but only 2 will union. I can go back and select the now (3) objects and try to union the remaining and it will not do it. I also would like to work with poly line solids but I cant find poly line options in the X16. can anyone help me out? Thanks! I was working through questions on beams and posts - check this out if you want the wood grain to be correct, which will not be the case when you join everything. Here is a library of beams, brackets, etc. I have put together for proper grain. Both Blocks (to explode and manipulate), and Symbols Millwork.calibz Link to comment Share on other sites More sharing options...
