mtldesigns Posted September 8, 2024 Share Posted September 8, 2024 What's the best way to get the lower wall line shown on the plan view to be a dashed line? Link to comment Share on other sites More sharing options...
DBCooper Posted September 8, 2024 Share Posted September 8, 2024 It looks like it will always draw a solid line when you are using "lower wall outline". I think you can get what you want by changing to "upper wall and lower wall" and then setting up the lower wall to be dashed lines with either a solid fill style or no fill style. Link to comment Share on other sites More sharing options...
JKEdmo Posted September 8, 2024 Share Posted September 8, 2024 I suppose the quick and dirty solution for limited scope would be a cad line over the top, set to white dashed? I tested on a project I have with a garage curb: Link to comment Share on other sites More sharing options...
robdyck Posted September 8, 2024 Share Posted September 8, 2024 This used to be a bit easier when we had line control of each side of the main layer. A simple workaround is to add a '0' thickness layer to the exterior of the main layer, all properties the same. Make the exterior line set by the layer, make the interior line dashed. Link to comment Share on other sites More sharing options...
mtldesigns Posted September 8, 2024 Author Share Posted September 8, 2024 5 hours ago, DBCooper said: lower wall to be dashed lines This only seemed to work when the layer was also dashed lines, I don't know why. But, in retrospect, I don't want the 12" CMU wall dashed anyways, because I am using that by itself in other places and don't want the dashed. What I did, is first, set up it to show both, then I drew a dashed line over that 12" extension, then just had the top wall show to get what I attached. I have my section arrow AND dimensions right on it, so there should not be ANY confusion. 1 hour ago, robdyck said: when we had line control of each side of the main layer I thought we did as well, that's I was looking for before I posted. Link to comment Share on other sites More sharing options...
