Hammer7 Posted September 2, 2024 Share Posted September 2, 2024 Why are labels showing up in layout when they are off in elevation plan view? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 2, 2024 Share Posted September 2, 2024 In an elevation camera view it and every other camera view and plan view each has their own "Display Options" dialog where in the plan view or camera view named layers can individually be checked ON or OFF. Your Wall Layer Names layer is obviously ON in the Display Options dialog for that view you are sharing. DJP Link to comment Share on other sites More sharing options...
DBCooper Posted September 2, 2024 Share Posted September 2, 2024 Open the layout box dialog. Check to see if it is actually using the same layer set as the elevation camera. If it's not that, then you might want to post the plan and the layout so someone could look into it more. Link to comment Share on other sites More sharing options...
robdyck Posted September 3, 2024 Share Posted September 3, 2024 If there has been any change to the layerset used by that view, the elevation view in layout will not automatically update to show the current layerset. You will need to relink that view and then it will update in layout to match the current layerset used by the elevation view. Link to comment Share on other sites More sharing options...
