leyi123 Posted Thursday at 07:12 PM Share Posted Thursday at 07:12 PM Hi all, I am using X15. I am looking into adding a sheet for wood framing details, to include things such as standard windows within wood framing flashing details, door to wall, roof to wall, stucco, wall to foundation, flashing membrane, etc. The house is pretty standard 2 stories with 2x4 exterior/interior walls, so general standard details would be good enough. My mentor told me this should be done by architect, not structure engineer.. .Does chief provide/generate these? What is the best way to get this done? Thanks! Have a great holiday and may the force be with you! -Leyi Link to comment Share on other sites More sharing options...
joey_martin Posted Thursday at 10:51 PM Share Posted Thursday at 10:51 PM Draw them manually, use the back-clipped back section camera and cut the details from your model, download the details library, bring CAD details into a CAD Detail and adjust. Many ways to do it. Link to comment Share on other sites More sharing options...
VHampton Posted Friday at 02:23 AM Share Posted Friday at 02:23 AM CA always has sample plans on the Home page. Not that they may be relevant to your project, but there's really helpful information, as well as some nicely detailed kitchens and baths. Check out a few of the plans and layouts for some boiler plate details and notes. Good stuff you will find there. I have spoken said Kuill. Link to comment Share on other sites More sharing options...
Kbird1 Posted 18 hours ago Share Posted 18 hours ago On 7/4/2024 at 12:12 PM, leyi123 said: so general standard details would be good enough Chief has some Standard "Starter Details*" , in the CAD Block Library , they may not be applicable Code Wise to your Local though, but will give you an idea on what is needed. *Those Details can be "unblocked" and altered as needed , just remember everything in Chief is true size (1:1) and not scaled until you send it to Layout. M. Link to comment Share on other sites More sharing options...
