Ed_Orum Posted June 29, 2024 Share Posted June 29, 2024 When create cad details I define them with a border box. All boxes are the identical width, but they vary in height. The border box and the Cad Detail is then blocked and saved. When the Cad Detail is sent to the layout, the program creates a second border box surrounding the Cad Block border box. This makes it time consuming to use the Align To Closest Edge tool, because I want the alignment to the original Cad Block, not the border created by the program. Is there a way to set the program generated box so it aligns with the Cad Block border box? It may be hard to see from the screenshot, but there are actually two boxes....I do not want the outer box, only the inner box. Anyone else run into this? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2024 Share Posted June 29, 2024 I find it is always a battle to get things just right in layout. We do have some pretty good tools to get the job done but there is always something that takes a little more time and effort to accomplish than it seems like it should. Not sure there is a solution for this exact problem but one thing that would fix it and I think would really help me out is layout box borders not being controlled by only a layer setting. If the boxes had individual controls like labels I think that would make a dramatic difference to how layout is done. I often only want a few layout box borders so end up using a cad line to accomplish it when needed. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 29, 2024 Share Posted June 29, 2024 On 6/29/2024 at 10:42 PM, Chopsaw said: Not sure there is a solution for this exact problem Expand I believe the easy solution is allow snap to objects in the layout box. That would make it easy to grab the CAD detail border and then position the layout box precisely on the layout sheet. Autocad (my frame of reference) does this easy. I wish Chief would do this. Interestingly, I recall Revit, like Chief, not having this feature and being a source of annoyance to me. The annoyance being we go to great lengths being precise with the model and then we have to monkey around trying for precision on the layout sheet. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2024 Share Posted June 30, 2024 On 6/29/2024 at 3:22 PM, Ed_Orum said: When create cad details I define them with a border box. All boxes are the identical width, but they vary in height. The border box and the Cad Detail is then blocked and saved. When the Cad Detail is sent to the layout, the program creates a second border box surrounding the Cad Block border box. This makes it time consuming to use the Align To Closest Edge tool, because I want the alignment to the original Cad Block, not the border created by the program. Is there a way to set the program generated box so it aligns with the Cad Block border box? It may be hard to see from the screenshot, but there are actually two boxes....I do not want the outer box, only the inner box. Anyone else run into this? Expand Chief doesn't snap the Layout Box directly to the CAD BOX of a detail (or any view/object it seems), so I usually use my own CAD_Alignment Lines (Layer) and a CAD Grid of Dashed Lines (in Orange) in My Layout Template where needed to quickly Center Details and 3D Images etc on those pages and then bump them around as needed with bumps set to 1/32" for lining up the Floor surface CAD lines etc . as you can see at that stage I also make my Layout Box Borders Orange as well...... I don't use or display Layout Box Border typically, so both Layer are just turned off before Printing. M. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 2, 2024 Share Posted July 2, 2024 Either turn off your layout box borders layer OR set the line style for those particular boxes to the invisible line style and then see if you can simply align using the automatically produced (but now invisible) borders. You can also align perfectly by: Creating a CAD Detail From View of your layout page Drawing one or more reference lines in that new CAD Detail Cutting and then using Paste Hold Position to place the reference lines in your actual view Using Point to Point Move to align your objects Link to comment Share on other sites More sharing options...
