can't find top view parallel perspective
HappyHausStudios
Changing the rendering technique is completely optional.  You can use whatever technique you want.  The key is creating an "orthographic" view and then using the "top view" tool.
Also, it is usually better to put pictures directly in your post instead of putting them in a pdf that needs to be downloaded and then opened.
