DreamDesign Posted February 14, 2024 Share Posted February 14, 2024 How to create a sloped wall in the vertical plane to connect the top and bottom part of a chimney that was different widths (tapers at the change in width). Link to comment Share on other sites More sharing options...
GeneDavis Posted February 14, 2024 Share Posted February 14, 2024 Roof planes or solids, and good luck with all the vinyl corner bead and J-stop. Link to comment Share on other sites More sharing options...
rgardner Posted February 14, 2024 Share Posted February 14, 2024 12 minutes ago, DreamDesign said: How to create a sloped wall in the vertical plane to connect the top and bottom part of a chimney that was different widths (tapers at the change in width). Use a roof plane. Link to comment Share on other sites More sharing options...
robdyck Posted February 14, 2024 Share Posted February 14, 2024 If I had to model this, I'd create a cad polyline profile of the chimney in elevation view. I'd use this cad polyline as a snapping guide to adjust the wall polyline. I'd also replicate the polyline twice and convert it to a 3d molding polyline to apply the outside and inside corner trim. And, I would be using a 3d solid for the sloped portions, again using my cad polyline as a snapping guide. All very fast and easy to do. Much quicker than dealing with the variety of settings in various dialogs. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 14, 2024 Share Posted February 14, 2024 Why not just model the whole thing as a 3D solid, explode it so that each face can be separately textured, and then use the p'line you began with for making the 3D moldings to mock up the outside corner and inside beads? Modeling it with walls seems more tedious. You have the two-story-plus end wall that is shaped, two upper walls for the chimney, two lower walls for the fireplace, thus five walls to draw. Then there are wall connections to deal with, plus whatever happens above the roof. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 14, 2024 Share Posted February 14, 2024 57 minutes ago, GeneDavis said: Why not just model the whole thing as a 3D solid, explode it so that each face can be separately textured, and then use the p'line you began with for making the 3D moldings to mock up the outside corner and inside beads? Modeling it with walls seems more tedious. You have the two-story-plus end wall that is shaped, two upper walls for the chimney, two lower walls for the fireplace, thus five walls to draw. Then there are wall connections to deal with, plus whatever happens above the roof. Some people want framing. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 14, 2024 Share Posted February 14, 2024 34 minutes ago, Michael_Gia said: Some people want framing. For this as-built? Link to comment Share on other sites More sharing options...
