KevinMyers Posted January 10, 2024 Share Posted January 10, 2024 Hi, anyone have a suggestion on how to shape cabinets to go under steps such as the ones in the pic attached? Link to comment Share on other sites More sharing options...
MarkMc Posted January 10, 2024 Share Posted January 10, 2024 On 1/10/2024 at 2:52 PM, KevinMyers said: how to shape cabinets to go under steps Expand Depends if you need to have the doors work or just to place there. Here's one way to start. Shown is the beginning of making working cabinets and another just a face. The procedure for just making faces is a lot less work. Start with an elevation. Mark the end of the cabinet run with a line. Take a detail from view Go to the detail and use the line that is bottom of stairs, add to it and resize to get a polyline of correct siz in the location you want, Close that pline and convert to a solid. Copy and paste into plan. Convert back to a polyline, then to a countertop Set thickness and height off floor. Add moldings with proper offset (sample included) Convert to cabinet door symbol, rotate so it is vertical. Set a stretch zone and change the bounding box (open the symbol included to see settings under advanced sizing.) If you want functioning cabinets you have to do something similar to what is included in the attached X15 plan. You will likely need 4 cabinet to make it work. If you want backs on the cabinets you need to make those as well (or just reflect a door symbol and live with the rails and stiles OR make a single new solid...) You may need more than one door symbol. Good luck trying to hinge the one on the far left or you image.. Angle cabinet.zipFetching info... 2 Link to comment Share on other sites More sharing options...
TeaTime Posted January 10, 2024 Share Posted January 10, 2024 That's a very lengthy way of saying "Cabinets in Chief Architect can only be Box shaped objects and cannot be shaped in the manner depicted" 1 Link to comment Share on other sites More sharing options...
MarkMc Posted January 10, 2024 Share Posted January 10, 2024 On 1/10/2024 at 6:42 PM, TeaTime said: cannot be shaped in the manner depicted Expand No it's the a long way of saying it's difficult. Here without finished back is a cabinet Link to comment Share on other sites More sharing options...
TeaTime Posted January 10, 2024 Share Posted January 10, 2024 Absolutely, you present an excellent guide and I commend you for it! But, some would argue that that's no proper cabinet. Maybe some day we'll get fully editable cabinet boxes. O' to dream! Link to comment Share on other sites More sharing options...
MarkMc Posted January 10, 2024 Share Posted January 10, 2024 On 1/10/2024 at 6:56 PM, TeaTime said: some would argue that that's no proper cabinet Expand But you can add a top and a back. On 1/10/2024 at 6:56 PM, TeaTime said: Maybe some day we'll get fully editable cabinet boxes Expand Maybe but not really high on my list. In 20 years, I've needed maybe a half dozen of these and another batch of arch top. Many could have been done with solids, several were re-used (when I remember when and for who they were done. :) Link to comment Share on other sites More sharing options...
KevinMyers Posted January 12, 2024 Author Share Posted January 12, 2024 Thank you so much! I will see if I can figure this out when I get back to this design. I'll probably have so many questions. -Kelly Link to comment Share on other sites More sharing options...
DBCooper Posted January 12, 2024 Share Posted January 12, 2024 The short answer is that there is no easy way to make an angled top cabinet. Mark's method will work but it does take a bit more work then I usually want to do. As an alternative, it is relatively easy to make a door with an angled top which you could then convert into a symbol and just place under the stairs. The only tricky part is trying to match the angle on the door top with the angle of the stair. In the picture below, I have a basic panel door with a left side "arch" where all you need to do is futz with the height to get it close to the angles you want. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 13, 2024 Share Posted January 13, 2024 On 1/12/2024 at 4:32 PM, DBCooper said: The short answer is that there is no easy way to make an angled top cabinet. Mark's method will work but it does take a bit more work then I usually want to do. As an alternative, it is relatively easy to make a door with an angled top which you could then convert into a symbol and just place under the stairs. The only tricky part is trying to match the angle on the door top with the angle of the stair. In the picture below, I have a basic panel door with a left side "arch" where all you need to do is futz with the height to get it close to the angles you want. Expand Could instead use a window and draw a roof at the rise angle and use match shape 1 Link to comment Share on other sites More sharing options...
