Roof Trusses sitting to low on top plate
capitaldesigns
I doing a small practice project using trusses. When I do a cross section I see that the trusses are not sitting on top of the top plates, they are sitting about 4" below the top plates. I'm sure there is a setting that controls how the trusses sit on the top plates. I don't know what that setting is.
I'm using X15. I attached a copy of the plan.
Thanks,
Mike
Truss Plan.plan
I was following along with this tutorial when I drew the plan. I did exactly what he was showing in the tutorial. His trusses sit on top of the top plates and mine sit below the top plates.
I just called tech support. They said to copy the dimension shown in "vertical structure depth" and paste in the the "heel height". This will place the truss on top of the top plates.
Thanks,
Mike
