Rytikom25 Posted February 25, 2015 Share Posted February 25, 2015 How can I place a microwave in the base cabinet? I've been trying for several hours now, and I couldnt find any tutorials on that except on placing it in the full height cabinet. do I need a specific microwave for that? or perhaps a drawer microwave? Link to comment Share on other sites More sharing options...
AriseDesign Posted February 25, 2015 Share Posted February 25, 2015 Can you add an appliance via the DBX editing the base cabinet? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 25, 2015 Share Posted February 25, 2015 Don't use a 'built in' microwave from the library. Create an 'opening' in your base cab and place a regular microwave by setting its floor to bottom height to fit the opening height. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 25, 2015 Share Posted February 25, 2015 Create an opening the size you need in the base cabinet. Place the microwave in plan view on floor adjust height and move into the cabinet opening. Link to comment Share on other sites More sharing options...
Solution dshall Posted February 25, 2015 Solution Share Posted February 25, 2015 There is a mw that fits in base cabinet in library Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2015 Share Posted February 25, 2015 As Scott said "built in micro" from library works using the appliance in the cabinet DBX- Often you have to resize the cabinet first, place the appliance, then change the cabinet size. If you want it to look like a standard micro in an opening use Dennis's suggestion but you can't move it into the cabinet by simply dragging or using the arrow keys. To drag hold down the ctrl key while moving. Once in the cabinet (even part way) the arrow keys work. OR use transform replicate-move. Your picture shows micro drawer- attached are a few. Some work better than others and may need the origins changed, didn't check them. These go in using the DBX. Might add version your using to signature. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 25, 2015 Share Posted February 25, 2015 There is a mw that fits in base cabinet in library Didn't know that - too easy. Wonder what the OP's problem is? Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2015 Share Posted February 25, 2015 My guess would be either- trying to drag a standard micro into a cabinet, or not using the dbx, or not resizing the cabinet. DAMHIKT . Link to comment Share on other sites More sharing options...
Rytikom25 Posted February 25, 2015 Author Share Posted February 25, 2015 thank you Mark for the file, I made it work! thank you all Link to comment Share on other sites More sharing options...
