decorators3 Posted November 23, 2023 Share Posted November 23, 2023 I am creating a walk out basement not just for the back but for the entire lower level. I am following the Video on walk out basements but when I add the terrain on Floor 0 it does not show .. it does not show anywhere, and those 3 trees are in my window constantly = very irritating. any assistance is welcomed Levina Link to comment Share on other sites More sharing options...
scottharris Posted November 23, 2023 Share Posted November 23, 2023 Levina, can you post the plan? Link to comment Share on other sites More sharing options...
decorators3 Posted November 23, 2023 Author Share Posted November 23, 2023 its a mess quantum dr.plan Link to comment Share on other sites More sharing options...
Solution scottharris Posted November 23, 2023 Solution Share Posted November 23, 2023 Levina - I opened your plan and took a 3D view. I'm seeing terrain. Link to comment Share on other sites More sharing options...
decorators3 Posted November 23, 2023 Author Share Posted November 23, 2023 what happened to me I wonder.. I still can't see it is it, maybe because of those 3 tress what are they for and how do I get out of it Link to comment Share on other sites More sharing options...
decorators3 Posted November 23, 2023 Author Share Posted November 23, 2023 its good now. I don't know what i did but its been going on all morning.. now its fixed .. must be one wrong access and off it went thanks for your help I appreciate it. Now i can continue with the completion Cheers Levina Link to comment Share on other sites More sharing options...
DBCooper Posted November 23, 2023 Share Posted November 23, 2023 Quote I still can't see it is it, maybe because of those 3 tress what are they for and how do I get out of it Your plan has "auto rebuild terrain" turned off. This means that anytime you do anything that might affect the terrain, the program will think it is out of date and needs to rebuild. That is why you are seeing the "3 little trees" icon following your cursor around. That is also probably why you were not seeing any terrain. You can either turn on "auto rebuild terrain" in your terrain dialog or just manually rebuild the terrain anytime you want to update it and see what it actually looks like. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 23, 2023 Share Posted November 23, 2023 6 hours ago, decorators3 said: I am following the Video on walk out basements but when I add the terrain on Floor 0 it does not show . As a general rule Terrains should be added on Level 1 and then altered with Regions, Elevation Lines etc up or down as needed..... Mick. Link to comment Share on other sites More sharing options...
