Jonathan3891 Posted November 21, 2023 Share Posted November 21, 2023 I'm trying to get accustom to using automatic roofs instead of doing them manually every time. I need a shed roof over the front porch and adjust the pitch so it lands a little over midway as shown below. How do I accomplish this? Thanks! New Construction.plan Link to comment Share on other sites More sharing options...
glennw Posted November 21, 2023 Share Posted November 21, 2023 Basically.. Make your 2 short end railings High Shed/Gable. Make the long front railing something like this using Upper Pitch. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted November 21, 2023 Share Posted November 21, 2023 If you want the shed roof to intersect the higher roof halfway up, consider using CAD in a section view and determining what pitch that might be. Might save you diddling with it after if you don't like the way a 2-pitch porch roof looks. Be sure to use a baseline height (i.e. H.A.P. : height above plate) that is in line with the rafters needed for the span and load. There is absolutely no reason to go with whole numbers for roof pitches, other than they are easier to type into a dialog box. If 2 7/8 in 12 looks exactly right, then that is what it should be. No framer or truss plant engineer is gonna blink at your fractional pitch, no matter what it is. 1 Link to comment Share on other sites More sharing options...
Solution SNestor Posted November 22, 2023 Solution Share Posted November 22, 2023 Made you a quick video; Chief Architect Premier X15 - 22 November 2023 - Watch Video 2 Link to comment Share on other sites More sharing options...
Jonathan3891 Posted November 28, 2023 Author Share Posted November 28, 2023 I forgot to turn notifications on for my post. Thank everyone for info on how to accomplish this. Link to comment Share on other sites More sharing options...
CJordanDesign Posted November 28, 2023 Share Posted November 28, 2023 Thank you Jonathan for this topic, I am also having issues with porch shed roofs. I have created a kitchen addition that includes a porch. I was able to get the shed roof over the porch as per SNester's very helpful video. However the roof area around the new kitchen bay window is all messed up and I can't seem to correct without messing up other roof lines. Any assistance is appreciated! Cathy Kitchen Addn V.4 8-9-23.plan.zip Link to comment Share on other sites More sharing options...
