GLASS
decorators3
When I  passes and or time  for some reason the program does not show me how much time or passes have elapsed.
I can let it ray trace overnight -  so I am assuming the longer it ray traces the "sparkles" disappear .  I though it might have something to do with the "index of refraction" which I have no idea what it means and can't seem to get explanation from the knowledge base except for a small mention. it is set at 1.5 but that's as much as I know about it
I will let it run but that takes up a lot of time when i have several projects going at  the same time
Thanks for your reply
Levina
2 hours ago, decorators3 said:
these sparkles appear in the  glass
Some of the Best Info on the Forum for Info on the Old CPU RayTracing is still Graham Korbey's  2017   " Lets CPU RayTrace" Thread here:
https://chieftalk.chiefarchitect.com/topic/14512-lets-ray-trace/page/4/?tab=comments#comment-130373
and specifically Speckles.........
https://chieftalk.chiefarchitect.com/topic/14512-lets-ray-trace/?do=findComment&comment=124786
Mick.
With the CPU ray trace, when glass reflects thru glass – as you have with the lower glass railing in front of the windows, those sparkles will not disappear.
If you use the PBR ray trace, we have a denoise option that removes the sparkles. The settings for the PBR exterior ray trace will be different than those used with the CPU ray trace.
thanks my PBR EXTERIOR RENDERINGS ARE NOT GOOD
Not sure if your Signature is upto Date ?   re X11,  but Scott's advice likely is aimed at X15 which is based on the totally new PBR View that came in X13, but Graham Korbey also has a thread called "Let's PBR" that covers versions upto X12.
Mick
Thank you  this info.. I have CA 11 so I would have been trying and trying to get the results that Scott has achieved but I do thank him for his input and have his answer saved to my computer.  When I can afford the upgrade I will have a go to his instructions.
Appreciate all your replies
Cheers
Levina
Cheers
Levina
Scott would need to comment back but as a Chief Employee I am sure He is using X15 and may not of noticed your Signature.
Chief is now all subscription , at $200mth/$2000 yr  though I think for the 1st yr they still offer 50% off the 1st yr if you upgrade to the latest version.
Mick.
@scottharris
