msmith964 Posted August 18, 2023 Share Posted August 18, 2023 Scott recently did a webinar and he used this cover sheet showing a bath project. This may seem silly, but I want to show my finish samples the way he did but I can't figure out he showed them at an angle. Any suggestions? I attached a pic of the sheet. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 18, 2023 Share Posted August 18, 2023 Pretty sure that is just a 3D perspective view of some solids with materials applied and sent to layout then some text labels in layout. Link to comment Share on other sites More sharing options...
TeaTime Posted August 18, 2023 Share Posted August 18, 2023 Pretty sure that's just a series of 3D Solids/Slabs. *Edit: JYNX!! Link to comment Share on other sites More sharing options...
ValleyGuy Posted August 18, 2023 Share Posted August 18, 2023 It is minute #49 of the Bathroom Floor Plan & Dimensions video # 10276 1 Link to comment Share on other sites More sharing options...
Solution scottharris Posted August 19, 2023 Solution Share Posted August 19, 2023 Attached is a simplified “materials & objects” plan (X15) I use for each of my projects. I bring this forward into each new project and then update it to reflect the materials or other items (like cabinets, islands or vanities) I want to render out for layouts or just to render the individual object. The cameras are saved to make it relatively easy to update and obtain the view I’m after. Hope this helps. Kitchen-bath-materials.zipFetching info... 2 Link to comment Share on other sites More sharing options...
msmith964 Posted August 20, 2023 Author Share Posted August 20, 2023 Thanks Scott!! 1 Link to comment Share on other sites More sharing options...
