DeLayDesign Posted August 9, 2023 Share Posted August 9, 2023 Hey Experts; this one has me stumped. I've tried all my tricks to get it to come back and I'm coming up roses. I messaged chief and they said it had something to do with the 'bearing line' and the windows... and he shared a video where he pulled it back to the inside of the framing (not something I typically do) and in their video it worked; but when I tried it - no go... Thoughts? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 9, 2023 Share Posted August 9, 2023 Is that an auto roof return or a manually placed roof plane ? Link to comment Share on other sites More sharing options...
DeLayDesign Posted August 10, 2023 Author Share Posted August 10, 2023 1 hour ago, Chopsaw said: Is that an auto roof return or a manually placed roof plane ? All Manual roof planes. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 10, 2023 Share Posted August 10, 2023 17 minutes ago, DeLayDesign said: All Manual roof planes. Manual usually gives you more control but did you happen to try auto ? Other wise you may need to post the plan or share the video. Link to comment Share on other sites More sharing options...
robdyck Posted August 10, 2023 Share Posted August 10, 2023 I've had this happen before. These are tricky to correct and I don't remember exactly how I fixed it. You will need to post the plan or share a file link with someone through a DM if you aren't comfortable posting it here. I've can help and I'll sign an NDA if that's important to you. Link to comment Share on other sites More sharing options...
HyperTrex Posted August 10, 2023 Share Posted August 10, 2023 Only time I see that is when the roofs don't line up at the same elevation. Maybe verify their heights in the dialogs? Link to comment Share on other sites More sharing options...
DeLayDesign Posted August 11, 2023 Author Share Posted August 11, 2023 6 hours ago, HyperTrex said: Only time I see that is when the roofs don't line up at the same elevation. Maybe verify their heights in the dialogs? I thought the same thing, but I checked all the perimeters. Chief originally said it had something to do with the windows and the roof not liking how they are interacting with it, but the roof in question is above the windows and I've never had windows cause this problem before. Link to comment Share on other sites More sharing options...
DeLayDesign Posted August 11, 2023 Author Share Posted August 11, 2023 Chief's official response: The issue existed in X15 as well, so hopefully there is a fix for it. Link to comment Share on other sites More sharing options...
MPDesign Posted August 11, 2023 Share Posted August 11, 2023 Hi Adam In the wall dbx, will the full auto roof return work? Link to comment Share on other sites More sharing options...
