TyDesign Posted June 30, 2023 Share Posted June 30, 2023 I have been trying to figure out how to have a transparent screen material that is transparent in Vector/Elevation view. Screen material is being shown correctly in the Standard Full Camera view. Any help would be appreciated! Both views are attached to this post. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2023 Share Posted June 30, 2023 If I remember correctly the last time I did a screened in Porch I reversed the colors on the Pattern Tab and played a little with it's size (grid) M. Link to comment Share on other sites More sharing options...
rgardner Posted June 30, 2023 Share Posted June 30, 2023 54 minutes ago, TyDesign said: I have been trying to figure out how to have a transparent screen material that is transparent in Vector/Elevation view. Screen material is being shown correctly in the Standard Full Camera view. Any help would be appreciated! Both views are attached to this post. This answer completely depends on the version you are using. Please add your signature so we can tell. Link to comment Share on other sites More sharing options...
TyDesign Posted June 30, 2023 Author Share Posted June 30, 2023 @rgardner I am currently using X15. Desktop: Windows 11, 11th Gen Intel(R) Core(TM) i7-11700, GeForce RTX 3080 Link to comment Share on other sites More sharing options...
SNestor Posted June 30, 2023 Share Posted June 30, 2023 What screen material are you using. You can probably use the "rainbow" tool to edit the material to make it more transparent. I created my screen material from the "glass block" material in Chief...and adjusted the material definition. Link to comment Share on other sites More sharing options...
TyDesign Posted June 30, 2023 Author Share Posted June 30, 2023 @SNestor I'm not having the issue in the 3D camera view. This is more for the Elevation/Vector view cameras. My work around has been drawing CAD boxes while adding a grid pattern and changing the transparency, in place of the screen. I'm trying to avoid the extra steps if possible. Link to comment Share on other sites More sharing options...
SNestor Posted June 30, 2023 Share Posted June 30, 2023 27 minutes ago, TyDesign said: @SNestor I'm not having the issue in the 3D camera view. This is more for the Elevation/Vector view cameras. My work around has been drawing CAD boxes while adding a grid pattern and changing the transparency, in place of the screen. I'm trying to avoid the extra steps if possible. The view in my post is a vector view. Same as an elevation camera...it's a vector view which is controlled by the "rendering technique". You should just go purchase my Screened Porch Library and save yourself a lot of hassle. Section Elevation Camera...vector view; Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2023 Share Posted June 30, 2023 1 hour ago, TyDesign said: @rgardner I am currently using X15. Desktop: Windows 11, 11th Gen Intel(R) Core(TM) i7-11700, GeForce RTX 3080 I recommend you put this in your forum sig. so you don't need to do it every time you post a question.... Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2023 Share Posted June 30, 2023 55 minutes ago, TyDesign said: My work around has been drawing CAD boxes Try this Material I used last time below, there are a number of threads here on the Forum about Screened Porches , try a search.................... MHD_Screen Material.calibz Mick. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 3, 2023 Share Posted July 3, 2023 On 6/30/2023 at 3:57 PM, SNestor said: You should just go purchase my Screened Porch Library and save yourself a lot of hassle. Totally agree! Link to comment Share on other sites More sharing options...
