Anyone Have This Happen?
ARF_PSG
So.., I know this may sound counter productive and not make much sense to the 99%, but i think i might have found a bug in the software (X-15).  Here's what happened:
When placing a default interior door I set the size to 2880 (Its a Swing door).  I then converted the door to a symbol and renamed it (I find it quicker for myself, to pick a premade door from the library browser). I then placed the door on a wall with perfect success.  It has all the components that I want and the type that i want. .  Here's where things get wonky.... I then change the size of the door to a 2080 and convert it to a symbol once again.  The difference now is it turned the new symbol door into a bifold door.   Does anyone know why a Hinged door would revert to a bifold door when the size is 24" or smaller?  Is this a bug Chief Crew?
I'm thinking this is something coded into the door logic -- I tested making a generic panel, a 3D Solid, an inch thick, 90" tall, 28" wide. Convert to Symbol - placed just fine, 28" wide door. (made of concrete, Perfect!)
Did the same at 26" - 26" hinged door.
Tried a 24" -- yup, 48" bifold.
I think the logic there is that if you're selecting from the Library a small enough panel, the assumption is that you wouldn't want to use that for a single panel door - 24" is too small. The only thing that size panel makes sense for is a bi-fold. Of course this is specifically when selecting the panel in the Library and just placing it right into a wall. Since we're not selecting a door TOOL, it's making an assumption. If we were to edit our door defaults to use that new 24" panel, that's a different story.
Alrighty.. So here's the next solution i need.  My default door Size is a 2880.  I place the door, i then resize it to a 2068.  I then convert to a symbol, and show advanced settings.  I then select Hinged. from Options.  This will make my door 24" however the height is no longer 80" its back to 96".  when i go into the object properties the height is 80", but on the floor plan its 96" How would i get around that?
You are saying it’s a 32”x96” door and when you go to place it then it’s a 32”x96” door….  You sure you aren’t confusing the 80 8’-0” as 80” in your mind?
    33836
    HSHomeDesignMatt
    HSHomeDesignMatt
  • Similar Content
    • By rlangman
      When a pocket door is used in a plan, and the information is populated into the door schedule, is there a way to account for the 4.5" at the top where the hardware is hidden in the wall above the door?  The header height currently appears the same as all the other interior doors, and does not seem to account for this.  The schedule does get the width of the pocket door opening correct (twice the width of the door panel).
      Is there a reason Chief does not include this information?
      Is there a way I could adjust my defaults so that this information is included on pocket doors in the future?
      I have a client who is self-building, and although I explained that my plans are not an instruction manual for building (I'm an interior designer, not an architect or engineer), and my standard disclaimer says "door schedule is for planning only - refer to manufacturer specs for all installation instructions".  However this client went and put the header at the height listed in the schedule and is now shocked that he has to reframe, when he bought his doors weeks after the framing began.  He's wondering why "my software didn't account for that".  His framers don't seem all that experienced either.
    • By JKEdmo
      Regarding door placement tool:
      Does Chief have any hotkeys that toggle the door orientation during placement?  For example, toggle between inswing / outswing and left / right?
      Thanks,
      Jim
    • By exallspanian34
      So, I'm working on this duplex, created a door schedule.... and the entry door labels are being mixed up somewhat with the doors into the garages.
      Both entry doors should be D07, and both Doors into the garage should be D09.... but one of each is switched around...  one of the entry doors on the plan is called out as D09, and one of the Doors into the garage is being called out as D07...
      And, yes, if I open the doors from the plan, they are showing up correctly in the dialog box.
    • By toucanskeleton
      The title basically describes it. Is there a way to display a door as open in certain views (i.e. an elevation view), but not in others (i.e. on the floor plan, or a different elevation view)? And, if I want it to display halfway open in 3D views, but not on the floor plan, is there a way to do that?
    • By McCallOfTheWild
      Hello everyone
      New to the Chief forum. I'll get right to it... I recently got magic plan for an iPad I have to easily do a floor plan when on site (Have always used pencil and 11x17 paper). It has it's ups and downs, but for the need to know dimensions (I shoot with laser, and it auto populates) it's been great and has cut my sketching time in half.
      I have learned that Magic Plan can export DXF files. I have been watching tutorials on YouTube, and have learned how to import DWF/DXF into Chief. Learned about layering and so forth.
      Here's the problem. When I import to chief and get all my ducks in a row, and layer all I can, chief won't recognize the cad windows when I go into perspective view. chief thinks they're all door openings in the wall when I Cad To Walls. How do I fix this? Using Chief x10.
      Thanks in advance.
