cmeyer9424 Posted May 8, 2023 Share Posted May 8, 2023 Hi, New to the forums! Wanted to see if anyone has a solution to these white dots that appear on my physical based renderings. When I first open the camera there is more white dots but when i let the camera adjust some go away but they never fully disappear. Any suggestions would be great! Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 8, 2023 Share Posted May 8, 2023 if you are using X15 there is a denoiser in the camera setup. I generally cap the live samples as 300 and set the "denoise when complete". the white dots should go away on the bottom right in the status bar you will see the samples increasing every time you move the camera. once you hit 300 (if you set it to that). it should stop and then denise Link to comment Share on other sites More sharing options...
Electromen Posted May 9, 2023 Share Posted May 9, 2023 1500 samples is very good. 2500 is excellent. It depends on the speed of your video card. 1 Link to comment Share on other sites More sharing options...
cmeyer9424 Posted May 9, 2023 Author Share Posted May 9, 2023 Okay I’m currently running X13. I can see about upgrading to X15. where do you see if something is 1500 or 2500 sample? thank y’all for the responses! Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 9, 2023 Share Posted May 9, 2023 on the status bar, lower right corner. if you pan tha camera you should see it restart from 0 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 9, 2023 Share Posted May 9, 2023 4 hours ago, cmeyer9424 said: I can see about upgrading to X15. CA went to subscription model on Jan 9th 2023, so if you missed that you will have to transfer to the new Model , though I think the 1st yr is 1/2 price. https://chieftalk.chiefarchitect.com/topic/37322-chief-architect-software-licensing-changes-beginning-january-10-2023/page/16/?tab=comments#comment-292771 But in X15 with the new Denoiser Option in RT you can run a 500 sample, in 60-90secs (depends on GPU ) and it cleans up the "dots" when done. It is best to "CAP" your samples so your GPU does run at max continuously like this......... Link to comment Share on other sites More sharing options...
cmeyer9424 Posted May 9, 2023 Author Share Posted May 9, 2023 Thanks I’ll give it a try if I can get upgrade to 15 Link to comment Share on other sites More sharing options...
joey_martin Posted May 9, 2023 Share Posted May 9, 2023 Just an FYI....these doors won't open with that window molding on the top. Link to comment Share on other sites More sharing options...
cmeyer9424 Posted May 9, 2023 Author Share Posted May 9, 2023 Haha yeah I noticed that. It’s not the correct molding. Just something similar to match existing for the rendering Link to comment Share on other sites More sharing options...
