VinnieVicon Posted March 15, 2014 Share Posted March 15, 2014 Hello, I'm need to build a deck with cable railings, are there any how to video or other ways to learn this.? X6 Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 15, 2014 Share Posted March 15, 2014 You can set your Railing Defaults to that type of panel or you can shift-select your intended railing walls and set them to that panel type. Just look in your LIbrary Browser for that panel type. DJP Link to comment Share on other sites More sharing options...
VinnieVicon Posted March 16, 2014 Author Share Posted March 16, 2014 Thanks David, I'll give a try. Vinnie Link to comment Share on other sites More sharing options...
VinnieVicon Posted March 16, 2014 Author Share Posted March 16, 2014 Hi David, I tried changing the square balusters to the cable rail in the catalog and the cables is running perpendicular not parallel like we'd expect. I'm not sure what I'm doing wrong. I've attached a picture to show you. Vinnie Link to comment Share on other sites More sharing options...
rgfeher Posted March 16, 2014 Share Posted March 16, 2014 I believe the railing has to be set type panel Link to comment Share on other sites More sharing options...
Gawdzira Posted March 17, 2014 Share Posted March 17, 2014 Yes, you are almost there but see pic one - Make the Rail Style to Panel See pic two - assign cables to the panel, not the balusters Link to comment Share on other sites More sharing options...
imodel Posted March 17, 2014 Share Posted March 17, 2014 Here is how I like to handle Cable Railings. cable rail.zipFetching info... Link to comment Share on other sites More sharing options...
