KristjanM Posted March 14, 2023 Share Posted March 14, 2023 I really like to have my window (or door) number represent what floor the object is on. I know I can do this manually but would like to use CA's numbering capabilities. I have seen a number of posts with regard to this but none provide a good solution. I also am aware that I can just add the floor number field to the schedule. So... using floor_number as a macro reference in the Schedule Number Prefix field, I can get the window number to display correctly on a plan view. On floor 1, I get numbers stating with 1. On floor 2, I get numbers starting with 2. However, the window schedule does not display the correct numbers. If I use the ObjectProperties macro, the floor numbers are correct. A glitch or what?? Window Numbering.plan Link to comment Share on other sites More sharing options...
DrawingABlank Posted March 14, 2023 Share Posted March 14, 2023 The macro %floor_number% is pulling for each object. Meaning it is also reporting what floor the schedule is on and not the windows. Cutting and pasting on second floor changes the shcedule numbers to W2-xx. Sorry that's not much for help on how to fix it but perhaps the 'why'. Link to comment Share on other sites More sharing options...
KristjanM Posted March 14, 2023 Author Share Posted March 14, 2023 Just tried something else. I have a custom field - Window #. I defined this as %schedule_number%. For example - window labeled as W205 on the plan view reports as W105 on the schedule. In object properties, schedule number is W205. Just seems like a glitch to me. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 14, 2023 Share Posted March 14, 2023 This is a little ugly and defies logic but looks like it will work for your specific situation: Link to comment Share on other sites More sharing options...
KristjanM Posted March 15, 2023 Author Share Posted March 15, 2023 Yes that works although there is an unwanted leading 0 in numbers above 9. ie. W208,W209, W2010, W2011. Thanks for the tip. I will have to play around some more. As great as the improvements in X15 are, I could do with much better flexibility in schedules for a start.. Link to comment Share on other sites More sharing options...
rgardner Posted March 15, 2023 Share Posted March 15, 2023 2 hours ago, KristjanM said: Yes that works although there is an unwanted leading 0 in numbers above 9. ie. W208,W209, W2010, W2011. Thanks for the tip. I will have to play around some more. As great as the improvements in X15 are, I could do with much better flexibility in schedules for a start.. Why not stitch schedules together based on floor and have W1-xx W2-xx etc? Very simple and accomplishes what you want. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 15, 2023 Share Posted March 15, 2023 If you're willing to pay for a little of my consulting time, I could set up a custom system that would fully automate this exactly like you want. Using the standard built in macros and methods though, I think your best bet is to either: Do as @rgardner suggested and just use multiple schedules Do as @Chopsawsuggested but get rid of the leading zero and maybe use something like a dash instead 1 Link to comment Share on other sites More sharing options...
KristjanM Posted March 15, 2023 Author Share Posted March 15, 2023 Ryan, That is a good suggestion and certainly gives a good result. My goal really is to reduce the need for manual tweaking for general things. A work in progress. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 16, 2023 Share Posted March 16, 2023 I've used the method Ryan mentions for years. Works great and is simple - one of my favorite words! Link to comment Share on other sites More sharing options...
