5FT-20Designs Posted February 25, 2023 Share Posted February 25, 2023 Has anyone had any problems importing X15 libraries into X15. Sometimes an internet connection is not available so I want to download the primary libraries I use to my system. I did a clean install so i didn't try to migrate X14 libiraries in X15. I keep getting this message, actually 56 times last night when I tried to copy a batch. LOL. The downloads are X15 versions. Link to comment Share on other sites More sharing options...
tundra_dweller Posted February 25, 2023 Share Posted February 25, 2023 I had this happen and I just copied my X14 libraries into the corresponding X15 folder. After that my X15 libraries were populated, and I got the little update icons on most of the library folders. I then hit the "Update Library Catalogs" button and everything updated and seems good now. Not sure if this is the best way to do it but it seemed to work. Link to comment Share on other sites More sharing options...
5FT-20Designs Posted February 25, 2023 Author Share Posted February 25, 2023 I found some of the libraries are not in the catalog anymore and several several must have downloaded and i tried to download again. Thanks Brett for your suggestion. I remember Wolf was combined with the Sub-Zero library last year. Link to comment Share on other sites More sharing options...
SummitCAD Posted March 15, 2023 Share Posted March 15, 2023 Hi have the same problem Didn't matter what version of existing library (x14, x13 & ext) Still didn't import my import my User Catalogs (LibraryDatabaseInterface.cpp(417): Error #272032176 "Error Updating Library Schema in User_Library: database disk image is malformed" 03/14/2023 06:44:38 PM Build: 25.0.3.69 Windows 64-bit) Link to comment Share on other sites More sharing options...
VHampton Posted March 15, 2023 Share Posted March 15, 2023 Same here - meaning same findings as tundra_dweller. Wound up opening Chief data base libraries in X14. Made a copy of the folder and saved to desktop. Opened Chief data base libraries X15 and removed data base library folder. Moved X14 data library into place. Bingo. All good. Observation... when setting up X15, most but not all library items made the transfer. My user library did not. That's why I had to go this route. Other have reported the same. Note: After going through this somewhat unique library transfer, allow some time for X15 to "load" all of the data. It takes about 5 or more minutes, and then everything should be fully stocked and ready to go. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 15, 2023 Share Posted March 15, 2023 On 2/25/2023 at 6:33 PM, 5FT-20Designs said: Has anyone had any problems importing X15 libraries into X15. Expand No DJP Link to comment Share on other sites More sharing options...
VHampton Posted March 15, 2023 Share Posted March 15, 2023 Interestingly David, on one computer there were zero issues. Another had the error messages. It must be fluke of som e kind. Link to comment Share on other sites More sharing options...
MPDesign Posted March 16, 2023 Share Posted March 16, 2023 No problems here. All libraries transferred as they should. Except for the discontinued ones. Link to comment Share on other sites More sharing options...
