heidistokoe Posted January 19, 2023 Share Posted January 19, 2023 Hi Everyone, I have been working on sending things to layout and I have noticed my text has gotten really pixelated when I am looking at my floorplan now. I will attach a photo. It has never been pixelated before. Any ideas how to fix this? Thanks! Heidi Link to comment Share on other sites More sharing options...
Chopsaw Posted January 19, 2023 Share Posted January 19, 2023 So this is a screen shot of layout in X10 ? How does it look if you print to PDF ? Link to comment Share on other sites More sharing options...
heidistokoe Posted January 19, 2023 Author Share Posted January 19, 2023 @Chopsaw this is a screenshot just in the main floorplan view. Not in layout. When I zoom in almost all the way the text gets clear and when I print it to PDF the text is clear. That’s why I can’t figure out why it’s pixelated when I’m zoomed out. Link to comment Share on other sites More sharing options...
heidistokoe Posted January 19, 2023 Author Share Posted January 19, 2023 @solver yes I have Link to comment Share on other sites More sharing options...
Chopsaw Posted January 19, 2023 Share Posted January 19, 2023 On 1/19/2023 at 3:25 PM, heidistokoe said: @Chopsaw this is a screenshot just in the main floorplan view. Not in layout. When I zoom in almost all the way the text gets clear and when I print it to PDF the text is clear. That’s why I can’t figure out why it’s pixelated when I’m zoomed out. Expand Just as a test try Rich Text with the same font and same color and the same size. It may have as much to do with your screen or video driver as much as anything else. If that makes no difference then feel free to post a test plan that displays the same issue since you don't likely have SSA with X10. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 20, 2023 Share Posted January 20, 2023 On 1/19/2023 at 8:28 PM, Chopsaw said: Just as a test try Rich Text with the same font and same color and the same size. It may have as much to do with your screen or video driver as much as anything else. If that makes no difference then feel free to post a test plan that displays the same issue since you don't likely have SSA with X10. Expand You could also try a true MAC Font like Andale Mono or Helvetica to make sure the Chief Font is not corrupted , you'll likely find both are easier to read anyway. M. Link to comment Share on other sites More sharing options...
glennw Posted January 20, 2023 Share Posted January 20, 2023 Heidi, I can confirm what you are seeing with the fuzzy text. It doesn't happen as bad with Rich Text. I can think of a couple of choices, all of which make an improvement. Show Line Weights. Use Rich Text. Turn on Print Preview. Make the text bold. Using a different font doesn't seem to make much difference. So...a couple of options, pick your poison! Without Print Preview: With Print Preview: Bold text: Link to comment Share on other sites More sharing options...
Chopsaw Posted January 20, 2023 Share Posted January 20, 2023 On 1/20/2023 at 6:17 AM, glennw said: I can confirm what you are seeing with the fuzzy text. It doesn't happen as bad with Rich Text. Expand I think it must be the 5K screen resolution Glenn... Perhaps Heidi has the same ? I just don't seem to get those results with a Windows Machine and a 1080 screen resolution. I do like the last one though. What setting is that ? Rich text is Vector so that does help in all situations to make it clearer. Where as room labels are not. Link to comment Share on other sites More sharing options...
glennw Posted January 20, 2023 Share Posted January 20, 2023 On 1/20/2023 at 7:18 AM, Chopsaw said: I do like the last one though. What setting is that ? Expand Hi Chopsaw, The last one was just zoomed in. 1 Link to comment Share on other sites More sharing options...
