Problematic wall niche and more
marlem2000
Go to solution Solved by Kbird1,
I started working on a wall niche thinking I wouldn’t have any problem but the more I walk, the more doubts I get.:(
Here they go a good bunch of questions related to this::unsure:
- If I remove the frame of the wall niche I get a brown texture that I want to replace by the one I used on the floor of the room. How can I expand that one inside the niche?
- Then, is it possible to change the color of the wall niche inside (not the whole wall)?
- The same way, is it possible to change the color of part of the wall?
- Now related to the cross section view, it’s almost impossible to select some objects because there are other elements in front of them. How can I do that? And, at the same time, why some objects aren’t visible in this view?
I know; too many questions. Sorry!:(
42 minutes ago, Bob-Roraback said:
Don't remove the frame Marlem just change the width to 0. Then you can specify a material of your choice
I did but I keep on getting the same problem :(
  • Solution
Where to start ?  :)
Turning the Frame Off in the Niche should just leave you with a drywalled opening , ( See TV Niche below)  so I suspect you wall definition may not be standard if you are seeing brown (probably the Framing?) however, for the desk area I would not use a Niche , but a Doorway with no Frame and use the Room Settings in the "Room" to apply floor coverings (carpet) etc, to match the Main Room and also to lower the Ceiling in the Makeup Area "Room" over the Desk. ( lower the Ceiling with an AIRGAP above the Ceiling Drywall so the Roof isn't effected.)
Wall Elevation Cameras only see what is in the room they are in, so it's possible you won't see objects in other Rooms , the View may also be back-clipped and thus you don't see objects outside the back-clip distance, however the Cross section view (pic no#2) is reversed ( niche should be on right not left) so I think you took it from the wrong side ?
* the strange Triangular lines in this view also tell me that you have not pulled the camera far enough past the surface of the wall..... those are actually the wall surface geometry triangles showing.
- Yes you can change the color of the Niche in the Material DBX ( probably says Drywall by default )
- Not all objects will be easily selectable in Elevation , you'd need to be more specific but I think you mean the Desk ? if the Cross section is through the desk? it will be very hard to select , best thing to do is in Plan View shorten the Desk surface so you see the End of the Object in the Elev. Camera then you can select it easily.
- Depending on the Material/situation you can use Wall coverings, Material Regions or even thin 3D Solids to put different materials on a Wall.
image.thumb.png.d935299c6e9ca98fb813085cb72ffd3e.png image.thumb.png.3c760d48e2fea8d532f605ad779ba0de.png
image.thumb.png.afc0a42dba19adda2ed86a261faba669.png  image.thumb.png.4d905c4bca8c6c9d7ab097dbe5ea297e.png     image.thumb.png.7f8c5b7ac6d8199e7a52295a80dc306b.png
If you need the plan to look at let me know........
Mick.
Hi, Mick! Many thanks for your help!:) Honestly, I don’t know exactly what you did with the doorway and the room view. I only work with this one to apply changes directly to the room and I understand I must work only with the doorway in this case.
The only thing I can do with it is just fill the hole left with a 3D Solid but I understand this is not the correct way to do it.:unsure:
Talking about ceilings in the doorway (room specification) I’m lost.:(
Then, in the case of the wall coverings, I think they only can be applied on the sides (interior and exterior).
Sure! If you can share the plan to take a look it will be welcome. I guess I'll discover many new things.:D
Your wall behind the desk niche is not like Mick's.  His is a "built" wall, by that I mean framed, so that finish surfaces (drywall with whatever finish is wanted) can be applied.  Yours looks like a single-layer something, which is why you get the lines.  And it is not the way a builder would build it.
Exactly, GeneDavis. This is the reason why I'm interested in finding out the proper way to do it. :)
Hi M, yes I think Gene is correct , it appears you have made 1 thick Wall?  eg 600mm rather than two walls at 100mm (2x4) like in you were drawing a Closet. you will see the difference in construction in my Pics above....
This may also explain your question about the Wall Coverings as you aree correct it can only be applied to either side ( or both) not the End, as you can see in my Pics there is a 100mm wall on the end too.
So make your Walls thin eg 50-100mm ..................
No Doorway shown                                       Doorway shown
*Doorways can be hard to select in plan view once the frame is turned off
image.thumb.png.680ccd4fb076716be36eec1c0d8710b9.png             image.thumb.png.169bbe25267263e996da347801da9e99.png
PLAN FILE : (default Chief Template Plan) :  M2000 - Forum Plan.plan
Mick
I don’t know if I understood correctly the plan.:unsure: Is it just a good amount of walls together? In that case, it’s possible to apply different covers on each one but I don’t know if this is the right way to do the work. :unsure:
Looks right from here  :)  or is something not working?
* share your plan if needed , just make sure the plan is not open in Chief when you try to attach it to the Post, it also needs to be < less than 14mb in size.
Mick.
Here it goes.:) What is strange for me is I though the process would be more complicated. I could build those walls by myself but I didn't think about it.:unsure:
test.zip
Looks good to me , or is there an Issue?
I see you didn't lower the Ceiling above the Desk though........ so you can place the lights.....
        Open the Room DBX
image.thumb.png.324b926b0f360bd3f22477be3b714779.png  image.thumb.png.b7f48c3de83f39904c91b4d23ec5c2d2.png  image.thumb.png.a1b38171519705656001f970fcb158bc.png
Plan............ M2000_test.zip
Mick
Right. I was planning to cover the hole up with a 3D solid and then adding the lights but I was not sure about the proper method so I  left it. :unsure:
Well a solid would work too , but you can check the plan I uploaded to see what I did too.
* the Lights will snap right to a Ceiling though which is one advantage.
Mick.
Mick.
True! I didn't know how to do it but I think I have found the way.:) As always, tons of thanks, Mick!:lol:
Looks fine , you might have to play with the lights though --- see the light ring around them? perhaps they are just too bright , but the light looks like it is blaeeding into the ceiling so the light maybe a little too high/low ie buried partially in the ceiling/solid material.
I know. I'm getting big fights with lights since I don't know how to set them.:unsure: By default (tilt angle: -90º,) they look like in the pictures. I can't notice much difference between 2850 lumens and 100; I don't know why. I always try to play with the standard view and physically based one but they both are totally different and that messes me up.:(
Yes it's best to do a SAVE AS version of the Plan if you really need PBR ,eg My Plan_PBR , as the lighting and even material properties can need to be quite different as well as the Sun Lumens. Chief Balances the sunlight against the Interior Lights ( no I don't know why )  but Chief sets the sun to maximum by Default which is 100,000 Lumens whereas you can probably get away with 500-5000 lumens depending on the scene.
There is this KB Article have you seen it ?  Under the Green Tools button on the right, you can also download the KBA as a PDF.
https://www.chiefarchitect.com/support/article/KB-00777/working-with-lighting.html
or these Videos
https://www.chiefarchitect.com/videos/watch/2426/physically-based-rendering-technique.html?playlist=102
https://www.chiefarchitect.com/videos/watch/2430/light-sets.html?playlist=102
https://www.chiefarchitect.com/videos/watch/70/rope-lighting.html?playlist=102
https://www.chiefarchitect.com/videos/watch/83/advanced-materials.html?playlist=102
https://www.chiefarchitect.com/videos/watch/10210/material-properties-how-to-import-set-the-pattern-visualize-in-3d.html?playlist=170
Mick.
Talking about lights is complicated.:unsure: I’ve been checking some of the links you sent and making tries in Chief Architect but the result is not clear.
For example, I’m working on a ship cabin design but I don’t know why the first room of the suite is dark and the second one is full of light in the physically based view.
Then, I think my graphic card is not working properly. I love night views but when I click on “toggle sunlight” the preview screen becomes totally black (it only happens with this option) and I need to remove the camera and open it again.:(
There are so many questions about lighting… Maybe it would be better to talk about this in other post in order to avoid a mess for users...
Hi Marlem,
There is a great series of videos on Ray Tracing on the Chief Architect website under Training Videos.  See attached screen shot to know what to look for.  The series is really well done and will help explain how this all works and how to get good settings for the lights.  The woman who narrates it also teaches for Chief through their One on One Personal Training program.
I agree with Mick, if you want to play around with the Ray Tracing, make a copy of your plan so you can adjust lights.
Good luck and let us know how it goes!  :)
Susan
Chief is probably seeing the 2nd area as a different Room and by default Chief only lights the Room the camera is in by Default , do you even have light(s) in the second area? ( where the bed is ).
It is possible your GTX 960 is struggling with PBR and it can not do  PBR-RTRT I think  ( PBR is the same as X12 , PBR-RTRT (Real time Raytacing) is in X13/X14 but the Videocard must support RTX from Nvidia , which the 960 does not have , you need a 2000,3000, or 4000 Series Videocard for that.
https://www.chiefarchitect.com/support/article/KB-03146/identifying-the-shader-model-of-your-graphics-card-in-windows.html
https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html
https://www.chiefarchitect.com/support/article/KB-01025/message-your-video-card-is-unable-to-provide-optimum-3d-performance.html
4 hours ago, SusanC said:
Hi Marlem,
Many thanks for the links, Susan!:lol: I'll check them out in the upcoming days since I've been working with lights configuration and it's a bit messy.:unsure:
I have recessed lights in the dark area but they don't reflect enough. Probably they need a proper configuration. For the moment lights in the plan are too weak.:(
I was checking my shader model and it seems it's enough for the programme. Maybe I should come back to version X12. Probably X14 is too much for my graphic card (and for me too!).:unsure:
In Standard View the lights need to be set much higher that in PBR to show and real effect , but also in the pics above there is only a couple of small recess light i can see and no light coming from the exterior ( windows or Doors) so you may need to ADD Lights ( these are "invisible" lights in 3D ) to help illuminate the space better.
Your card looks fine for X14 , I can see it supports Extended Formats too , which is also important for X13 and X14 , but as the 960 does not support RTX technology you could try turning off GPU Ray Tracing and see if views still go black.
If this is a Laptop? you should make sure that Chief is using the Nvidia Card not the Intel Graphics card and that it is using the best Driver for it (Ver. 526.86) too....  3rd Pic....
https://www.chiefarchitect.com/support/article/KB-03140/forcing-chief-architect-programs-to-use-a-specific-graphics-card-in-windows-10-11.html
image.thumb.png.573977100e272b6ef64c5dcf7d5a721e.png image.thumb.png.203fdceca85d5160e1f9bc6360c33b0e.png   image.thumb.png.a34fffd0869a8d66212d60e202bae146.png  image.thumb.png.f3c280d3873fe2d1797bc409bfff9951.png
 What do you mean with "invisible" lights? Maybe some hidden lights behind a forniture or something?
The problem is that it's not posible to edit the GPU Ray Tracing in my case. I don't know why.:(
My computer is not a laptop but it's old. In my signature you can check my hardware specifications.
this can be done by navigating to 3D> Lighting> Add Lights addlights.png?1643818217     but since you can't see them in 3D cameras you can place them anywhere , more about it near the bottom here :
The problem is that it's not possible to edit the GPU Ray Tracing in my case. I don't know why.:(
I guess because your Card does not support it , so Chief has already disabled it.
I can see in the pics above your computer has (2) Graphics cards , so you do need to check the Render Tab in Chief and make sure Chief is using the Nvidia Card. Show me your Render Tab pls.
image.thumb.png.03d81adf9235036c52506f0b4cf521b6.png   image.thumb.png.d6821eccfa129e897407f21aca8c431c.png
    33296
    Sekamc
    Sekamc
  • Similar Content
    • By marlem2000
      Hi, everybody
      This question is not exactly related to technical issues about Chef Architect but I don’t know what to do. Let’s see… how can I explain this?
      I’m really bad designing my own furniture so I usually download stuff from pages like 3D Warehouse. I save everything in the User Catalog. I try to keep everything in order and in different folders but, as you can guess, working with so many things is a mess.
      I try to clean these folders regularly removing furniture I don’t use anymore but my hard disk is a disaster. I’ve been updating the software and now I don’t know where all the libraries are (including the stuff I downloaded). I’m scared of deleting the wrong "Chief Architect Premier X Data" folder.
      Then, another strange thing that happens while working with downloaded symbols is that, after adding them to my catalog, their textures are lost. Doesn’t Chief Architect keep them?
      I don’t know if I’m missing anything… How can I “clean” the software? Many thanks!
    • By Kbird1
      Tip Added here after being found buried in a post in the Q&A Section as I thought it would be useful for Others, Thx Chopsaw.
        *I have also added some PDFs and links for GIMP.
      Making SEAMLESS TEXTURES using Gimp.                    * this info is in the PDF below too
       It's an open source (free) photo editing software available at https://www.gimp.org
      Tutorials are here : https://www.gimp.org/tutorials/
      Direct link as of :
      Mar.13th 2023
      https://download.gimp.org/gimp/v2.10/windows/gimp-2.10.34-setup.exe
      1. Open the image file in Gimp.
      2. Edit > Copy, then Edit > Paste as new layer.             Paste it as a new layer three times so you have a total of four copies, each on their own layer.
      3. Image > Canvas Size. Exactly double the width and height of the image/canvas size.
      4. Use the alignment tool to align each layer in its own corner (so they are all visible, not overlapped).
      5. Use the "flip" tool to reverse/mirror three of the layers. Leave the top-left corner alone.
              Reverse the top-right corner horizontally.
              Reverse the lower-left corner vertically.
              Reverse the lower right corner horizontally and vertically.
      6. Export the new image. This will now be a seamless texture when tiled. Choose it as the texture file for your material.
      7. Adjust the scale of your new material since the size of the image is now larger.
      * the Info above is in the PDF below too
      SEAMLESS TEXTURES USING GIMP.pdf
      I also made a PDF of the Latest Release Notes
      GIMP 2.10.20 Release Notes.pdf
      Mick
    • By marlem2000
      Hello!
      I hope everybody is enjoying this year that’s ending.
      I’d like making a question before 2023 comes. Is there a way to make some kind of “up holes” in a wall in order to set some puck lights up too?
      First, I tried with a wall niche but it’s too thin. I don’t know if I’ll have to use a pony wall or other but I have never worked with them so I’m feeling a bit lost. Any idea?
      Many thanks and Happy New Year!
    • By MN_JohnH
      I can't figure out why my walls are not meeting the roof.
      I run into this a lot and usually finagle walls by puling on their handles etc but changing from gable wall to hip wall etc seems to make no difference in how the wall acts.
      I just want them to act like when I first drew them where they just automatically connect with the roof.
      plan.plan
    • By KimJansen
      Dear CHIEFERS, can someone please advise me on how to create new foundations that will then be the default foundations - as shown in attached image.
