Peaked Window
edcsteve
Go to solution Solved by Garybills,
I am sure this is an easy problem, but for the life of me I am not finding it.  I need to create a window that fits in a gable, peaked in the center, it will not match the roof pitch.  It is for an as-built plan, any help would be greatly appreciated.  Thank you
22 hours ago, Garybills said:
With a little work you can do it in the window specification, shape. The only thing is the casing in the peak flattens off a couple inches and it will only let the side offsets go to 29 1/2" instead of 30 on the 60" window.
A couple things:
1.  You don't actually need 2 offsets.  Setting one or the other to 30" works just fine and does NOT result in casing with the little flat spot on the top.
2.  You can also simply use a Tudor Arch with the radius set to zero.
36 minutes ago, Alaskan_Son said:
A couple things:
The Tudor Arch works great, thanks for the info.
