Jambruins Posted November 23, 2022 Share Posted November 23, 2022 Attached is my plan. I am having trouble getting my dormers to work. The dormer on the side opposite the stairs is good but I can't get the dormer over the stairs to work. I would like the dormer wall to be right along the right side of the stairway but when I move the wall there it says it can't create the dormer because walls are in the way. If I delete the railing around the stairway it removes the stairway opening. I also cannot change the siding material on the dormer over the stairs but I can on the opposite dormer. Thank you for the help. house.zipFetching info... Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 23, 2022 Share Posted November 23, 2022 In the shared plan file Default Settings - Walls - Exterior Wall was not set to your predominate exterior wall, also Default Settings - Materials - Exterior Wall was set to Blue Siding. The dormers will be easier to edit when exploded, try it. Other than that I did not find much wrong and was then easy to straighten out the dormers. DJP Link to comment Share on other sites More sharing options...
SNestor Posted November 23, 2022 Share Posted November 23, 2022 Many things need to be fixed in this plan...I took some liberties to fix things. "Somewhat Fixed" plan attached. Ahern house manual dormers - Fixed.plan The main floor roof (10/12) I made using trusses checked...but the dormer roofs are "stick" framed with 2x8's. I raised the main 10/12 roof off the plate because the floor was sticking through...and, the dormer side walls were sitting on a floor that was above the top surface of the roof. You could fix that using a solid...but, I thought it better just to raise the roof. Don't paint walls...nothing but trouble. Make new wall types. I also created a new saved plan view called "roof plan view". Link to comment Share on other sites More sharing options...
Jambruins Posted November 24, 2022 Author Share Posted November 24, 2022 Thank you both for the help. Steve, can you save the file down to version x12? I can't open the file because it was created with a newer version of chief. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 24, 2022 Share Posted November 24, 2022 On 11/24/2022 at 1:52 PM, Jambruins said: Steve, can you save the file down to version x12? I can't open the file because it was created with a newer version of chief. Expand You can't "down-save" Chief Plans, there is no backward compatibility only forwards. ( never has been actually ) Also might be worth a look at the reasons Not to Paint Can Exterior Walls in chief as Steve Mentions.... https://chieftalk.chiefarchitect.com/topic/31850-paint-can-tool-material-painter-best-practices/?tab=comments#comment-250698 M. Link to comment Share on other sites More sharing options...
Jambruins Posted November 25, 2022 Author Share Posted November 25, 2022 Steve, does your plan have auto roof still on or did you turn it off? Link to comment Share on other sites More sharing options...
Jambruins Posted November 25, 2022 Author Share Posted November 25, 2022 Steve, and did you use auto dormers or did you manually create the walls and roof for the dormers? Link to comment Share on other sites More sharing options...
