900 series aluminum railings for chief architect
GP202256
Quote
Is there 900 series aluminum railings for chief architect
Not that I know of, but you might want to search the manufacturer or bonus libraries:
https://www.chiefarchitect.com/3d-library/index.php?r=site/library&reset=true
If you are trying to create the wagner 900 railing that Robert posted above, this would be very easy to build yourself, except for the multiple post styles.  Chief doesn't handle multiple post styles out of the box so you will have to use some kind of a workaround.  The simplest way to handle this would be to just manually place the corner posts on top of the one that Chief does automatically.
This recent post had some different ideas for how to handle different post styles:
https://chieftalk.chiefarchitect.com/topic/37231-newel-posts-between-post-to-beam-posts/
If you want something else, then you should probably post a picture with an example.
  • 2 weeks later...
