Brick Veneer on Outdoor Fireplace Wall
DRyeHD
I'm trying to represent an outdoor fireplace as shown on the .png attachment.  My approach wad to frame the firebox with brick veneer on the outside.  Then add the high gable walls as attic walls.  The problem I'm having is when I pull the attic walls into the narrow part of the chimney, it deletes my wall that the fireplace and mantle are on.  I've tried several ways of doing this over about 4 hours but can't get it to work.
Could anyone give me a way to do this?  I"ve attacheed the .pln file if you want to see where I am on it.  Thanks in advance for input.
Ingram2b.zip
@Renerabbitt I downloaded your firepace stack about a month ago (thanks for making tools like this available).  The tapered part of the fireplace is your symbol.  After looking at your symbols, I created my own lower "cabinet" so I could move the firebox around.  I may go back and take a look at your whole stack again.
@MPDesign the outside is exactly the way I need it, but the inside is not right.  There's got to be a combination that will work.
I've been off of this project for a few days...hence the late reply.  I'm back on it and will be working with the ideas you all supplied.  I'll post an update when I get further along, get it right, or give up again!  Thanks for both your input.
Have a Happy Thanksgiving.
@DRyeHD - Damon, made you a long rambling video to explain how to fix this plan.
1 - Please don't drag wall tops/bottoms....just creates so many problems.
2 - Painting wall materials is also a big hassle...try to learn to create new explicit wall types.
3 - Don't place attic walls on the first floor...
Damon - Outdoor Fireplace - many issues - Watch Video
@SNestor, I was about to send @Renerabbitt and @MPDesign another question about the gable walls and rails.
Thanks so much for the video.  I've watched it carefully and will be correcting some things accordingly.  Thanks for calling out some bad habits (and being kind about it) - dragging walls in elevation view, painting a material over another instead of defining a wall type, and more.  I'll be working through this on my plan and incorporating your tips on all future plans.
I'll go ahead and ask about the deck railing before I get started.  I'm going to follow the tips in the video.  But can I add the deck railing directly under the gable walls?  Since @SNestor explained where the gable walls need to be (not on the 1st floor) I'm thinking the railing should work the way its supposed to.  I'll send a picture of the covered deck with rails when I'm finished.  Thanks again, all, for your input.
@DRyeHD - Yes, you can draw a railing wall and have a gable end wall above it.
Chief typically will auto generate a gable wall using the same type wall below it. So...If you use an interior-4 wall for the railing...the gable end wall will be the same type. You can change it manually....or use the wall type for the railing that you would like the gable end wall to be.
    32648
    paintitblack
    paintitblack
  • Similar Content
    • By ChiefArchitect
      Kerry, our rendering specialist, did an amazing job decorating the Saltbox house's interior with simple but dramatic materials that make this quaint style beautiful and welcoming.
    • By ChiefArchitect
      Our content development team is continually developing new objects and materials to be used in renderings like these.
      Some catalogs that might appeal to this home's style include Country Primitives / Farmhouse No.1 and Country Primitives / Farmhouse No.2. Those aren't the only option though, the 3D Library features over 350 catalogs that can be downloaded to compliment your designs.
    • By Doug_N
      I have a client for whom I am designing a sunroom.  He wants a wood stove in the design, and I was surprised that there are none in the Chief Architect library. Has anyone done one?  Something like this?
    • By fmrkva9525
      Alright guys need a few suggestions... So I'm a custom woodworker and I'm building built-in bookshelves and a mantle unit for a customer. Normally I'm able to come up with certain techniques in modeling custom millwork projects that are "out of the norm" or beyond the standard cabinetry presets here in chief, but this one is a little more complex.... The unit I'm building consists of floor to ceiling bookshelves with a fireplace surround and mantel in the center. So far easy to do.. but in this particular build the customer wants the bookshelves to have angled dividers/faceframe-stiles that the shelving will go in-between. I've attached some photos to this post so you can have a better idea of what I'm doing here. I build everything custom so I know exactly how I will build the unit, I'm just unsure of how to create a model for it here in chief. I'm assuming id use some sort of 3d polyline to create the angles, but I'm not too familiar with using this feature. It would be nice if I could somehow use a partition and angle it in between two cabinet sides, and manually add shelving in between. If anyone has any ideas id be eager to hear...
      EXAMPLE OF SHELVING
      ELEVATION VIEW OF UNIT I AM BUILDING
