NealFlora Posted November 3, 2022 Share Posted November 3, 2022 I have room with a window, shelves and a cabinet. From the entry door the Shelves are on the left, the window faces the door and the Cabinet is under the window. There are shelves on either side and below the Window. The Back Clipped Cross Section appears to be a great tool to create an image to send to my builder for showing dimensions (You can add dimensions and notes). However no matter what I do the Back Clipped Cross Section shows everything reversed (Shelves on the Right, Cabinet reversed, etc). By drawing the Back Clipped Cross Section in the opposite direction I can get the orientation to show correctly but then there is no window? Not sure what I am doing wrong Link to comment Share on other sites More sharing options...
GeneDavis Posted November 3, 2022 Share Posted November 3, 2022 Place the wall elevation view camera and report back. Link to comment Share on other sites More sharing options...
NealFlora Posted November 3, 2022 Author Share Posted November 3, 2022 Gene, Shelves do not show up. Window does, Cabinet is orientated correctly Link to comment Share on other sites More sharing options...
rgardner Posted November 3, 2022 Share Posted November 3, 2022 On 11/3/2022 at 10:00 PM, NealFlora said: Gene, Shelves do not show up. Window does, Cabinet is orientated correctly Expand Search the help files for layers and layer sets and read up on default settings. Link to comment Share on other sites More sharing options...
DBCooper Posted November 4, 2022 Share Posted November 4, 2022 Post the plan or at least a picture (of the floor plan and the view you are seeing). Link to comment Share on other sites More sharing options...
NealFlora Posted November 4, 2022 Author Share Posted November 4, 2022 Thanks guys, I figured it out. Had to use Cross Section/Elevation and draw in the correct direction. Link to comment Share on other sites More sharing options...
