Dummy needs Help AGAIN
raltd9245
Why don't you post a picture of the door you'd like?
I do what Joey suggested and I've made plenty of commercial doors!
image.thumb.png.c43ae50f88a191be1ac0d59560b6c86a.pngimage.thumb.png.009db0b276759c5d70da464ebf1089b6.pngimage.thumb.png.90f1addb386606a26d31db608bf4dfc5.png
I usually use a 2" casing, 1/2" depth, 0" reveal, no sill / threshold. Change the hardware, done.
@raltd9245You know Ron, while the plan view representation isn't 100% perfect, what I'd suggest you do is set your door default before starting the plan. If it's already started, no big deal, you can still set the default and the add those settings / info to doors already in the plan.
Using the Object Information Panel you can add as much info as you want and it will all populate into the schedule. Let's take a quick look at an example using a Trudoor KD Drywall Frame.
The manufacturer has a nice list of specs on their website:
Construction
Heavy Duty; 16-Gauge Cold Rolled Steel - meets the requirements of ANSI A250.8-2014 (SDI 100)
Handing
Handed - LH/RHR, RH/LHR
Jamb Faces
2-inch Jamb and Head Faces
Stop Height
5/8” Stop Height
Rabbets
Unequal Double Rabbets Standard
Returns
1/2” Double Return
Corners
Exact Fit Die-Mitered Corner Connections
Hinge Reinforcements
7-Gauge Hinge Reinforcements
Strike Prep
4-7/8” Universal ASA Strike Preparation (Blank Strike Jambs Available)
Closer Reinforcement
Optional 14-Gauge Door Closer Reinforcement
Silencer Preparation
9/32” Silencer Preparation
Pair Head Preps
Flush Bolt Strike, Silencer Preps
Optional Preps
Blank Hinge Jamb For Continuous Hinge, Deadbolt Strike, Electric Strike, Exit Device Strike Reinforcement
Anchors
Screw Adjusting Compression Anchors on Jambs, Dimpled Base Anchor Holes
Fire-Rating
Optional – WHI / ITS up to 90-Minute Fire-Rating (Mylar Label) - Fire-Rated Assemblies must be in accordance with NFPA 80
Finish
Factory-Applied, Baked-On, Rust Inhibiting Primer (No Special Color Options) – Not intended to be a finish coat. It is recommended that finish paint (top coat) be applied after installation
Buy American Act Compliance
Meets Buy American Act – Made in USA
Mfg. Hinge/Lock Locations
Steelcraft Locations Standard (Ceco, Curries, and Custom Locations Available)
Any or all of this information can be replicated into the OIP so it is added to you schedule. All you need to do is decide what information you want in your door schedule and then it becomes a bit simpler to build out the door default settings in Chief. Here's an example from a previous project of mine just as a point of reference.
image.thumb.png.97649ecd9c1920c7ef9bddd983158af3.pngimage.thumb.png.57fc6056b9fd394d0b90f31f7506b02a.png
