decorators3 Posted August 3, 2022 Share Posted August 3, 2022 Hi I have been watching the video tutorials on exterior rendering primarily the lighting features and effects . Can anyone tell me about PARALLEL lighting placed facing the buildings exterior??? I can't locate anywhere. Cad arrow does not convert ...also where do I find the lighting for the interior rooms that show a yellow glow . I've tried the electrical but only see the auto LGIHT for ceiling which is a light fixture not a glow. Its probably so easy but for the life of me I can't figure it out. My exterior renders are not bad but would be more affective with the features available in said video Much thanks Levina Link to comment Share on other sites More sharing options...
MPDesign Posted August 3, 2022 Share Posted August 3, 2022 Main menu, 3d, lighting, add lights Link to comment Share on other sites More sharing options...
decorators3 Posted August 3, 2022 Author Share Posted August 3, 2022 I did what you suggested but I did not see any option for parallel light .. the screenshot attached shows the exterior rendering lighting specification dialogue options for night time rendering but does not explain how to create or find the parallel light. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 3, 2022 Share Posted August 3, 2022 In plan view you do 3D > Lighting > Add lights. Click and place the light outdoors. Circle with rays all around. Then select it, open for spec, and change from point light to spot light, and then you can rotate and aim it in plan view. Before now (X14?) you could do "parallel," but now they term it "spot." Same effect. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted August 3, 2022 Share Posted August 3, 2022 Quote In plan view you do 3D > Lighting > Add lights. Click and place the light outdoors. Circle with rays all around. Then select it, open for spec, and change from point light to spot light, and then you can rotate and aim it in plan view. You can click to to place a point light but if you drag you can create a spot light pointing in the direction you want. Link to comment Share on other sites More sharing options...
decorators3 Posted August 10, 2022 Author Share Posted August 10, 2022 I have been working on this feature for days but just cant get the look of the purple shadows shown in the video as parallel lighting You can click to to place a point light but if you drag you can create a spot light pointing in the direction you want. have done this but still not working. sort of a purple glow but I end up having the blue spot light showing on the house. When I use the Launch Assist for DARK I end up with the Caustic feature which slows down ray trace and when I uncheck the Caustic I loose the Launch Assist Which one should I use EDIT OR LAUNCH ASSIST. Also when does the sun toggled off come into it ?? The videos are great and I am learning for sure but they are not perfect and do not explain the variation in the two ray trace options unless I am missing something. I have been using CA for many years and still playing with exterior ray trace issues. My interior ray traces are totally different PBR works well but not for exterior tracing You all have been very helpful and thanks in advance for your assistance. Levina Link to comment Share on other sites More sharing options...
