Finger hole
Artisan_TH
On 7/29/2022 at 11:47 AM, Artisan_TH said:
How do I create a finger hole in the door?
Not too hard to make a Door and subtract a cylinder in my case to make the hole, if they are Bypass you will need two symbols with one offset the thickness of the Door eg 1/4" in the Y Origin of the symbol so it looks right in 3D
Mick.
    32367
    Echodrewer
    Echodrewer
  • Similar Content
    • By Allen43
      I'll new to Chief and have learned that this form might be one of the best resources I have ever used. I am trying to streamline my design process and to do that I would love to be able to change cabinet ends to finished or paneled faster and easier. I tried to make a SP to do this, but I couldn't figure it out. I also thought that there might be a way to do this with macros is a SP, but I know even less about macros than I do Chief.
      Any help is appreciated, and if it's not possible that's fine I'll know not to spend more time on this.
    • By Designers_Edge
      I have searched the Chief Architect website and also here.  I have X14 now and want to show sliding doors on some base cabinets.  Perhaps I am missing the options to adjust this in the cabinet specifications.
      Would appreciate someone helping me find this.  Seems like it would be available in the library with the resurgence of Mid-Century Modern.  Thank you.
    • By EMBARC
      I'm looking to see if there is a way to separate the material between the frame and the reveal of a window (or door).
      When painting the frame it also paints the reveal the same material, and visa versa.
      I have been a long time Chief user but never found a solution - so hoping someone has a good trick. Using X13 currently.
      Thanks in advance!
    • By BryanXG
      When you place a cabinet as a blind corner, CA automatically adjusts the filler and door size for the exposed portion of the cabinet.
      The filler is 2" wide... we typically work with 3" fillers to make sure there is clearance on the adjoining cabinet hardware.
      How can this default be changed?, as having to add a vertical blank each time is getting old.
      Thank you for any suggestions.
    • By Bee-am
      Hi everyone,
      I'm experiencing an interesting phenomenon with Cabinet Shelf Specifications that contain 3 or more library-based shelves in Chief Architect Premier X13. As indicated below, when I add a 3rd unique library object (i.e. wire shelf) to a shelf, somehow the previous library-based shelf (2) "breaks" and changes from (1) to be the 3rd library object. As such, I wanted to find out if that's the intended behavior or it's a bug - and whether there are any useful workarounds. I could have used separators directly at module-level but the cabinet module needs to be covered by double doors.
