simonas Posted January 20, 2015 Share Posted January 20, 2015 Hi all, I've found this photo Chiefs website How there hatches are visible in the plan?I'm talking about Deck wood and stone hatch. I assume this is made as a separate room polyline with hatch. Or is there other(easier) way to show top view with hatches and not black/white. Link to comment Share on other sites More sharing options...
mattyt12 Posted January 20, 2015 Share Posted January 20, 2015 The Decking looks like the auto generated decking with a dark brown linestyle and a lighter brown fill. The stone path Ild say is a terrain feature with a light grey fill duplicated and converted to a plain polyine then given a stone fill with a dark grey line colour and the transparent hatch fill checked. Both could be generated with just polylines duplicated, bottom layer with a solid base fill, the top with a hatch pattern set to transparent. Bit of a PIA, wouldnt be a bad feature being able to choose the background colour as well as the line colour. Link to comment Share on other sites More sharing options...
glennw Posted January 20, 2015 Share Posted January 20, 2015 You can get a similar appearance with a Standard Rendered Orthographic Overview (Top View). But I haven't got a clue about the dimensions unless they are some sort of overlay. Link to comment Share on other sites More sharing options...
rlackore Posted January 20, 2015 Share Posted January 20, 2015 Rooms, decks, terrain... all you have to do is assign a fill pattern. Link to comment Share on other sites More sharing options...
tommy1 Posted January 20, 2015 Share Posted January 20, 2015 To get this, I used a cad box with a colored fill set to the back, a cad box with pattern fill set to the front. For the chair, I used the cad block of the chair moved to the front. Link to comment Share on other sites More sharing options...
simonas Posted January 20, 2015 Author Share Posted January 20, 2015 On 1/20/2015 at 2:33 PM, rlackore said: Rooms, decks, terrain... all you have to do is assign a fill pattern. what do you mean by that assign a fill pattern? room polyline with fill? or what? Link to comment Share on other sites More sharing options...
ArthurDent Posted January 20, 2015 Share Posted January 20, 2015 Rooms can have fill patterns. Just set it up in the room dialog. Link to comment Share on other sites More sharing options...
rlackore Posted January 20, 2015 Share Posted January 20, 2015 On 1/20/2015 at 4:34 PM, ArthurDent said: Rooms can have fill patterns. Just set it up in the room dialog. Yes, just set it up in the Room dbx. Be certain you have the Rooms layer turned on. Terrain can also have a fill - set it up in the Terrain Perimeter dbx. Link to comment Share on other sites More sharing options...
simonas Posted January 20, 2015 Author Share Posted January 20, 2015 Yes, thanks. Learned something new today. Link to comment Share on other sites More sharing options...
keysersoze Posted January 21, 2015 Share Posted January 21, 2015 Too bad we still cant change start point coordinates for hatch pattern for each room to show tile patterns. Link to comment Share on other sites More sharing options...
simonas Posted January 21, 2015 Author Share Posted January 21, 2015 On 1/21/2015 at 9:16 PM, keysersoze said: Too bad we still cant change start point coordinates for hatch pattern for each room to show tile patterns. Totally agree! Instead I have to draw tiles with line tool... even autocad has this! Chief allow to choose start point for hatching. And add solid color with hatch on top please!.. How basic is that. 1 Link to comment Share on other sites More sharing options...
mattyt12 Posted January 21, 2015 Share Posted January 21, 2015 Worst is that you can adjust the origin of patterns in elevation Link to comment Share on other sites More sharing options...
