OldBarnDesign Posted June 30, 2022 Share Posted June 30, 2022 Hello fellow Chief users, This is my first post. I'm working on my very first project in Chief Architect (I'm a converted Sketchup user ), and will likely be peppering you fine people with all kinds of questions. I hope I can become a Jedi at this tool at some point to help out the community. Thanks in advance! You'll see in the attached images I have a brick water table that I made using a pony wall. You can also see on either side of the windows I have a brick wall cap that is supposed to run the length of the wall at 24" high. It appears when I add exterior casing to my windows the casing at the bottom ends up cutting into my water table, removing the brick wall cap that I want. I still want the window casings on the sides and on top of the window, but I'd like to remove the casing at the bottom so my cap doesn't get clipped. Is there a trick to pull this off? Thanks! Cody Link to comment Share on other sites More sharing options...
OldBarnDesign Posted June 30, 2022 Author Share Posted June 30, 2022 Thanks Eric for the message and the solution! You're my favorite already I should have my signature setup, and will definitely watch the videos and search as much as possible. I do my best to help myself but man this program can do about everything except your taxes. Link to comment Share on other sites More sharing options...
rgardner Posted June 30, 2022 Share Posted June 30, 2022 1 hour ago, OldBarnDesign said: but man this program can do about everything except your taxes. I bet @Alaskan_Sonor @Joe_Carrick could probably write a macro for the taxes part…. 2 1 Link to comment Share on other sites More sharing options...
Sandilocks Posted May 23, 2024 Share Posted May 23, 2024 On 6/29/2022 at 10:12 PM, OldBarnDesign said: Thanks Eric for the message and the solution! You're my favorite already I should have my signature setup, and will definitely watch the videos and search as much as possible. I do my best to help myself but man this program can do about everything except your taxes. I need to know this exact same thing and I can't see who answered you or the answer!... Help.. Link to comment Share on other sites More sharing options...
TeaTime Posted May 23, 2024 Share Posted May 23, 2024 Not sure why he deleted his comment, equally unsure if this is the same solution, but turning off the window's Apron removes the bottom casing allowing the Pony Wall to come up right to the bottom of the window. The Sill has to be present for this to work, but can be covered by the pony wall, or set to use a much smaller molding profile. Link to comment Share on other sites More sharing options...
Sandilocks Posted May 23, 2024 Share Posted May 23, 2024 Got It! Thank you! Link to comment Share on other sites More sharing options...
