myrtsbnye Posted June 15, 2022 Share Posted June 15, 2022 Hello all, I work for an architect who likes to make numerous revisions, options, etc (I get paid by the hour so I say bring it on). She would like each one saved and labeled in case the client wants to go back to an old version (For example I have 52 plan files for a home we just completed). Problem I have is this is very cumbersome and nonefficient. Also, every time I rename a file I have to redo the layout file. With all the online videos on the Chief website and youtube I can't find help with this...I assume I am not asking the correct questions to find what I am looking for. I have looked for file management. Where should I look? Thanks for any help. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 15, 2022 Share Posted June 15, 2022 1 hour ago, myrtsbnye said: Problem I have is this is very cumbersome and nonefficient. Also, every time I rename a file I have to redo the layout file. You can relink the Layout to the new RENAMED .Plan File easily enough , though I am not sure if that is well documented? however if you have 52 plan files ie Rev.1 - Rev.52 then do you need a Layout Revision for Each Plan File too? relinking the Layout : Link to comment Share on other sites More sharing options...
rgardner Posted June 15, 2022 Share Posted June 15, 2022 I personally use the same plan name for all so they don’t have to be delinked. Just duplicate your folder and give the folder newest date. Inside you have your house as built new and layout files with the same name. I.E. I am working on a large addition for client Morales. Job folder 2022_Morales Addition > Plans > CA > 20220615_Morales Addition: inside that folder I have 2022_Morales AB.plan 2022_Morales New.plan and 2022_Morales.layout files next revision the folder gets duplicated and renamed with the current date. Chief will look at the same folder for the plan first so it won’t unlink. Link to comment Share on other sites More sharing options...
robdyck Posted June 15, 2022 Share Posted June 15, 2022 2 hours ago, myrtsbnye said: Also, every time I rename a file I have to redo the layout file. If you want to save files as backups, rename the backups, not the main file! When I need a backup file saved I will rename the backup file by adding the date or drawing issue # to the back of the file name. Often, I'll also add a 'z' to the beginning so it drops to the bottom of the file list. Lots of different ways to handle it. Link to comment Share on other sites More sharing options...
OkcDesigner Posted June 16, 2022 Share Posted June 16, 2022 I do not get to 52 revisions. Here is how I do it. Plan number 2400. Layout and plan are named 2400 If I make a revision or option, I save plan 2400 as 2400 - 1, exit and go back to 2400 and make the changes. If I have to make another revision, I save 2400 as 2400 - (next number), exit and go make changes to 2400. If you ever have to go back to another version. Save 2400 as 2400 - (next number) Then go into old version, and save as 2400 This method keeps plan 2400 as current plan and all the revisions as - (version Number in order). I rarely change the layout specific to a plan version. however if I need to then Save 2400 - (version Number) layout file This has worked for me well and keeps me from having to guess what plan file is the current version. 1 1 Link to comment Share on other sites More sharing options...
robdyck Posted June 16, 2022 Share Posted June 16, 2022 @OkcDesigner Perfect description! I was going to add that description but now, there's no need! Link to comment Share on other sites More sharing options...
myrtsbnye Posted June 17, 2022 Author Share Posted June 17, 2022 Thanks to all, the options make sense (considering what I have been doing). Thanks for your time. Link to comment Share on other sites More sharing options...
