wazzubrad Posted June 6, 2022 Share Posted June 6, 2022 Anyone know how I can get the Fascia, Soffit, Drip Edge to add to the Schedule? I can't locate in the Category List, it's not under Roof Trim, in my setup anyways. But Frieze board, Gutter, and Ridge Cap is. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 8, 2022 Share Posted June 8, 2022 try the materials list Link to comment Share on other sites More sharing options...
Solution rgardner Posted June 8, 2022 Solution Share Posted June 8, 2022 On 6/6/2022 at 6:52 PM, wazzubrad said: Anyone know how I can get the Fascia, Soffit, Drip Edge to add to the Schedule? I can't locate in the Category List, it's not under Roof Trim, in my setup anyways. But Frieze board, Gutter, and Ridge Cap is. To get them into a schedule you are going to have to add some custom Fields to your roof planes and then show them in your schedule: You can add Global macros or custom ones. Use a Object information macro pointed to the edge of a roof plane to see what can be added. But globally you can get all of these: 1 Link to comment Share on other sites More sharing options...
wazzubrad Posted June 11, 2022 Author Share Posted June 11, 2022 On 6/8/2022 at 10:35 AM, rgardner said: To get them into a schedule you are going to have to add some custom Fields to your roof planes and then show them in your schedule: You can add Global macros or custom ones. Use a Object information macro pointed to the edge of a roof plane to see what can be added. But globally you can get all of these: Ryan, this is awesome and very helpful. Thank you for taking the time to put this together. Link to comment Share on other sites More sharing options...
rgardner Posted June 12, 2022 Share Posted June 12, 2022 1 hour ago, wazzubrad said: Ryan, this is awesome and very helpful. Thank you for taking the time to put this together. Glad that was helpful. To give back to future users who may be searching for this you can mark the one that answers your question as the solution as well as mark other pertinent and helpful answers with upvotes and likes as well. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 12, 2022 Share Posted June 12, 2022 1 minute ago, rgardner said: To give back to future users who may be searching for this you can mark the one that answers your question as the solution as well as mark other pertinent and helpful answers with upvotes and likes as well. Also let us know how it works out. Some of those values were not reporting correctly the last time I checked so make sure you are confident that that math is working before you publish the schedule. 1 1 Link to comment Share on other sites More sharing options...
wazzubrad Posted June 13, 2022 Author Share Posted June 13, 2022 Guys. I am still going through this trying to get it dialed in and accurate. I marked Ryan's post as the solution, thank you for the reminder. Chopsaw, I am learning basics of Ruby as time allows so hopefully will get these custom fields dialed in and schedules will be correct. Thanks again Link to comment Share on other sites More sharing options...
