buzzsaw204 Posted May 30, 2022 Share Posted May 30, 2022 hi, is there a Setting for have Air Space in the Vaulted Ceiling to drywall, when you uncheck [No Flat Ceiling Over Room] when you check this...the drywall is mounted to the Rafters....is there a setting to able to drop the Vaulted Ceiling plane lower?? Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 30, 2022 Share Posted May 30, 2022 You manually create ceiling planes and set their baseline height as you desire. DJP Link to comment Share on other sites More sharing options...
Solution HumbleChief Posted May 30, 2022 Solution Share Posted May 30, 2022 31 minutes ago, DavidJPotter said: You manually create ceiling planes and set their baseline height as you desire. DJP ..or you can add an 'air gap' under the rafters in the roof structure dialog box. Curious, why would you want a space between the drywall and the rafters? How would you mount the drywall if not to the rafters? Might be missing something. 1 2 Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 30, 2022 Author Share Posted May 30, 2022 4 hours ago, HumbleChief said: . How would you mount the drywall if not to the rafters? Might be missing something. it'll be using Truss with that Depth,.....14" to 16". Link to comment Share on other sites More sharing options...
HumbleChief Posted May 30, 2022 Share Posted May 30, 2022 5 minutes ago, buzzsaw204 said: it'll be using Truss with that Depth,.....14" to 16". There's a bunch of vids relating to building with trusses. Well worth the time. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted May 31, 2022 Share Posted May 31, 2022 If you are doing parallel chord trusses at 16" depth, simply set your roof structure up that way, with 16" deep rafters. Chief will position the drywll ceilings and your envelope is all set for your trusses. Chief does not generate truss framing. You do it, manually. Watch some training videos. Do NOT set roofs to auto-frame. Place all trusses where they belong. I set the ridge size in the framing spec dialog to 2x4, so when I autoframe the roof all the ridge and valley fill gets placed. Autoframe will place all the subfascia per your size specs. The only time you draw ceiling planes is when you're doing ceilings that aren't flat and pitches don't match roofs above. Link to comment Share on other sites More sharing options...
