tdoyle Posted January 15, 2015 Share Posted January 15, 2015 Chief is not allowing me to pull windows tight into corners. The included image is showing the tightest Chief will allow the window, about 5.5", these are 8" walls. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 15, 2015 Share Posted January 15, 2015 if its a Auto Bay window you may need to explode the Bay to resize the window 1st..... you may also need to check the option for "ignore casing " on resize in Defaults Plan and set the minimum separation smaller in Defaults Windows for less framing play with the setting in the Bay Window Options here: M Link to comment Share on other sites More sharing options...
evergreen Posted January 15, 2015 Share Posted January 15, 2015 Not sure what you are after exactly, but when I frame out for a window, I need to have the "room" for, well, "the framing" the studs, trimmers, header to properly install the window... not to mention room for interior/exterior trim. Your situation looks a bit "tight". 1 Link to comment Share on other sites More sharing options...
MikeJG Posted January 15, 2015 Share Posted January 15, 2015 if its a Auto Bay window you may need to explode the Bay to resize the window 1st..... you may also need to check the option for "ignore casing " on resize in Defaults Plan and set the minimum separation smaller in Defaults Windows for less framing play with the setting in the Bay Window Options here: Bay window Options Tab 1.jpg M Sorry this is a bit off topic but how do you explode a bay? I know you can explode a dormer, but I don't see a similar option for bays. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 15, 2015 Share Posted January 15, 2015 You don't explode the bay. When selecting the bay click on the window. This will select the bay. Now hit the tab key and you will now have the window selected to modify it. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 15, 2015 Share Posted January 15, 2015 If you want to adjust the walls of a bay just build it using walls instead of using an auto bay window. Link to comment Share on other sites More sharing options...
Solution tdoyle Posted January 15, 2015 Author Solution Share Posted January 15, 2015 I was not using auto bay. But I did figure it out. Two things going on. The first was that even though "Use interior casing" was unchecked the default numbers were still interfering with moving the window in tight to the corner, setting those numbers at 0", even though I was not using interior casing allowed me to move the windows in tight to the corners. The second, and would have made the first irrelevant, was checking "Ignore Casing for Opening Resize" under Default Settings, Plan, General Settings. Thank you Kbird1. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 15, 2015 Share Posted January 15, 2015 You don't explode the bay. When selecting the bay click on the window. This will select the bay. Now hit the tab key and you will now have the window selected to modify it. Yes wrong term I guess..... I meant Open to access the trimmer and components dialog the tab key or next button will get you to the window itself that you clicked on instead of the Bay so you can adjust them individually , and tighter to the corners depending on framing and Casing etc. Normally each Auto Bay Window is sized automatically depending on Bay Size and the framing and casing settings otherwise. thanks Alan. M. Link to comment Share on other sites More sharing options...
