Accordian Door
schrlmbr
Go to solution Solved by schrlmbr,
Use a bifold door/glass/. Adjust framing, suppress casing/sill adjust height from floor and overall height. Larger windows use more units and mull together.
Funny, after posting that I'm not exactly sure what an accordion door is? Either way I think you s could use bifold doors mulled  together.
OK, here is another approach.  slab bi-fold doors 12" opening just gang doors together.
The block is not right but I guess you could create a new one. Also need to change/omit
the labels.  I blocked the 4 doors and made one label for this particular situation.
If you want to go to the next level create a block and assign it to blocked doors.
