buzzsaw204 Posted May 1, 2022 Share Posted May 1, 2022 hi, i have a piece of 3D Solid drawn on the Elevation and painted with a Hardie Board siding and I would like to show that Hardie Brd siding area in the Matr. List. when i generate the Mat. List, it only calculate the Plan View area of that 3D solid, W x L = 1sf, into the Mat. List how can i populate the 3D solid area (elevation view) into my Materials list. Link to comment Share on other sites More sharing options...
GeneDavis Posted May 1, 2022 Share Posted May 1, 2022 What is your goal? A material list that shows quantity for the various Hardie plank areas of a project? If your Hardie is set to, say, 6", for which the plank width is 7.25", the material list will return the quantity in lineal feet. Just like in your example. Something else needed? Link to comment Share on other sites More sharing options...
robdyck Posted May 1, 2022 Share Posted May 1, 2022 1 hour ago, buzzsaw204 said: hi, i have a piece of 3D Solid drawn on the Elevation and painted with a Hardie Board siding and I would like to show that Hardie Brd siding area in the Matr. List. when i generate the Mat. List, it only calculate the Plan View area of that 3D solid, W x L = 1sf, into the Mat. List how can i populate the 3D solid area (elevation view) into my Materials list. For solids, this does behave differently in X14 than in X13. You could report this to Chief to examine the functionality to see if it reports as Chief has intended. In the meantime, you could use a material region. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 1, 2022 Share Posted May 1, 2022 From your pics, you may need to redefine the Material as AREA not Linear AND you need to Edit the Materials in the Components Tab of the Solid * Warning X14 just Hung (crashed) when I changed it to AREA here........ okay 4 1/2 mins later Chief allowed me back in...... grrrrr It seems Chief , even with Area specified ( above) is using depth X width for the area calculation .... not Height (thickness for a solid) x width Update..... The Surface area is being calculated correctly so , you can use you own macro in the Count row of the Component Tab to get what you need currently though this shouldn't be need (owner.surface_area/2).round(0) for larger areas this is better (owner.surface_area.floor/2).floor Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 2, 2022 Author Share Posted May 2, 2022 8 hours ago, Kbird1 said: ....for larger areas this is better (owner.surface_area.floor/2).floor THAT IS IT!! thank you Kb. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 2, 2022 Author Share Posted May 2, 2022 On a related topic.... now that i have 4 Materials on applied on 4 - 3D Solid objects, and have the Area. Can I generate/make a "Custom Schedule" be created for those 3D Solid objects? basically, it's just taking that Material List, the Excel spreadsheet format, and making a "Custom Schedule" with 4 of those Column. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 2, 2022 Share Posted May 2, 2022 13 hours ago, buzzsaw204 said: Can I generate/make a "Custom Schedule" be created for those 3D Solid objects? I thought this was possible now in X14 but perhaps not? In which case Wall Material Regions could be used instead if you need a Schedule and a Materials list. M. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 2, 2022 Author Share Posted May 2, 2022 37 minutes ago, Kbird1 said: .... Wall Material Regions could be used instead if you need a Schedule and a Materials list. YES, Material Region from now on!! Link to comment Share on other sites More sharing options...
