Gravitie2002 Posted April 29, 2022 Share Posted April 29, 2022 Hello, Does anyone know how to link my plans to layout dynamically when i do a revision. So, when i do the first layout for the first plan, its ok, things work fine, but when i do a revision eg, rev 1 and i save both the plans and layout as revision 1. the elevations in the layout does not change to reflect the changes in revision 1, I have to go in and physically relink each elevation to repoint to the new elevation, this is daunting especially when you have 30 or 40 elevations. My question is; is there a way to point that new layout sheet to automatically update all those elevations to the new plan dynamically? or am i going about setting up the revisions incorrectly? Link to comment Share on other sites More sharing options...
MarkMc Posted April 29, 2022 Share Posted April 29, 2022 F1, layout, After you link to the file then Tools, layout, updated layout views, update all views. Sometimes you also need to select update all plot line views. Link to comment Share on other sites More sharing options...
rgardner Posted April 29, 2022 Share Posted April 29, 2022 5 minutes ago, Gravitie2002 said: Hello, Does anyone know how to link my plans to layout dynamically when i do a revision. So, when i do the first layout for the first plan, its ok, things work fine, but when i do a revision eg, rev 1 and i save both the plans and layout as revision 1. the elevations in the layout does not change to reflect the changes in revision 1, I have to go in and physically relink each elevation to repoint to the new elevation, this is daunting especially when you have 30 or 40 elevations. My question is; is there a way to point that new layout sheet to automatically update all those elevations to the new plan dynamically? or am i going about setting up the revisions incorrectly? Welcome to the forums. You can change the referenced files directly using tools>Layout>Referenced files. That being said a good file system/organization will take this step out of the equation. There are several power users who can offer training on how to setup a good file organization system. We really appreciate it if you can fill out your signature in your profile with basic information such as what software and version you are using as well as some basic computer specs so that the answers can be correct for your needs. Hope this all helps! 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 29, 2022 Share Posted April 29, 2022 4 hours ago, Gravitie2002 said: My question is; is there a way to point that new layout sheet to automatically update all those elevations to the new plan dynamically? what I've gone to is once I sent the plans to the customer, before I come back and open up the plans to do another revision, I create copy of the plan in the directory using windows explorer. Then you never need to do the above. One half dozen or the other Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 29, 2022 Share Posted April 29, 2022 I personally think one of the most efficient methods is to simply maintain a statically named Main plan. Only rename a version when you are dropping it and only relink a plan to layout when it becomes absolutely necessary. See below for a little more info. https://chieftalk.chiefarchitect.com/topic/25572-save-as-plan-with-layout/?do=findComment&comment=205297 1 Link to comment Share on other sites More sharing options...
